where to fine a b18c5 wire harness
why do you need an itr harness, why don't you just use something like this http://rywire.com/store/9293-i...7e511? much cheaper than an itr harness too.
It is a subharness, you use it along with your stock ls harness and it adds all the necessary wiring and plugs for vtec. you will need a chipped obd1 ecu with your choice of engine management and a tune for your lsvtec to run properly.
launch control is in the chip on the ECU, you will need to have your ecu professional socketed then search on ebay for custom chips, some sellers offer completely custom settings for launch control, shift light, etc
