dc5r cams....how can you tell if they are real deal itr k20a cams?
Old Nov 4, 2008 | 08:22 PM
brxtacy's Avatar
Default dc5r cams....how can you tell if they are real deal itr k20a cams?
how can you tell if they are the real deal? i know on bseries itr and ctr cams they have rings on the ends to tell them apart....what about kseries?
Old Nov 4, 2008 | 10:28 PM
keepinitrehaal's Avatar
Default Re: dc5r cams....how can you tell if they are real deal itr k20a cams? (brxtacy)
bump
Old Nov 4, 2008 | 10:39 PM
brxtacy's Avatar
Default Re: dc5r cams....how can you tell if they are real deal itr k20a cams? (keepinitrehaal)
https://honda-tech.com/zerothread?id=1976583
i found this, but it also is indefinite....
Old Nov 4, 2008 | 10:47 PM
square_1's Avatar
I think there is a little sticker on one of the lobes?
Bump!
Old Nov 5, 2008 | 05:40 AM
turboteg2nv's Avatar
Find the specs and measure it with a micrometer.
Old Nov 5, 2008 | 05:41 AM
brxtacy's Avatar
Default Re: dc5r cams....how can you tell if they are real deal itr k20a cams? (turboteg2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv &raquo;</TD></TR><TR><TD CLASS="quote">Find the specs and measure it with a micrometer. </TD></TR></TABLE>
dont have one....and there is supposed to be visible ways to tell em apart, just like on the bseries
Old Nov 5, 2008 | 03:38 PM
nahonda04's Avatar
Surje.motorsports
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brxtacy &raquo;</TD></TR><TR><TD CLASS="quote">
dont have one....and there is supposed to be visible ways to tell em apart, just like on the bseries</TD></TR></TABLE> pm ntcustoms, he has a set and may be able to help you. why do you want dc5r cams anyways?
Old Nov 5, 2008 | 10:00 PM
02 i-vtec's Avatar
05 type s cams are identical to the type r cams, same size cam lobes and i think the same part numbers... look into it, check clubrsx. there was a big dicussion about it
Old Nov 6, 2008 | 09:01 AM
brxtacy's Avatar
Default Re: dc5r cams....how can you tell if they are real deal itr k20a cams? (nahonda04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nahonda04 &raquo;</TD></TR><TR><TD CLASS="quote"> pm ntcustoms, he has a set and may be able to help you. why do you want dc5r cams anyways?</TD></TR></TABLE>
cause they are better than the oem 03 rsx cams.....ive seen multiple dyno graphs of them making anywhere between 235 and 243 whp in k20a2's....with all my mods anyways....and they are oem and i can get them dirt cheap and with s2000 springs and retainers and you can rev to 9000 too....oh and the dc5r cams give you more midrange and top end torque too, the low gears are already pretty useless in my car anyway so i need it to pull all the way to the top
Old Nov 6, 2008 | 11:50 AM
nahonda04's Avatar
Surje.motorsports
cause they are better than the oem 03 rsx cams.....ive seen multiple dyno graphs of them making anywhere between 235 and 243 whp in k20a2's....with all my mods anyways....and they are oem and i can get them dirt cheap and with s2000 springs and retainers and you can rev to 9000 too....oh and the dc5r cams give you more midrange and top end torque too, the low gears are already pretty useless in my car anyway so i need it to pull all the way to the top</TD></TR></TABLE>they are not that much better.. what other mods do you have that you will get 235-243whp?
Old Nov 6, 2008 | 11:58 AM
brxtacy's Avatar
k-pro, rbc manifold, throttle body and adapter, hondata gasket, rdx turbo injectors, aeromotive fpr, dc race header, skunk2 megapower full exhaust, clutchmasters stg2clutch, 8lb flywheel, wally 255, etc.
i already got the cams springs and retainers.....so i should know in the net couple weeks if it makes a difference...i also plan on later getting a tsx exhaust cam....for just a little extra bump....
Old Nov 6, 2008 | 12:02 PM
02 i-vtec's Avatar
theres no way that you are going to make 243 on itr cams, when i had itr cams in my car with rbc, throttle body adapter, injen cai, buddyclb exhaust, dcrh, motor mounts and kpro i only made 215 on a dyno jet... and i have the k20z1 motor... ull be around 210-220 with ur mods... you should just get satge 2 cams...
Old Nov 6, 2008 | 12:06 PM
brxtacy's Avatar
Default Re: (02 i-vtec)
mine is at 220 right now...without the cams.....but before you ask i dont have the graph to show you cause the dyno was done in GA and i now live in alabama and havent dynoed it since getting the car here....and i have the k20a2...its a lot different...but well see..i could be wrong
Old Nov 6, 2008 | 01:40 PM
nahonda04's Avatar
Surje.motorsports
Default Re: (brxtacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brxtacy &raquo;</TD></TR><TR><TD CLASS="quote">mine is at 220 right now...without the cams.....but before you ask i dont have the graph to show you cause the dyno was done in GA and i now live in alabama and havent dynoed it since getting the car here....and i have the k20a2...its a lot different...but well see..i could be wrong</TD></TR></TABLE>i wanna see the dyno after you get them installed. i don't believe that they will make an addtional 15-23 whp, maybe 5-12 at most... if any at all!!
stage 2 cams ftmfw
Old Nov 6, 2008 | 02:11 PM
brxtacy's Avatar
Default Re: (nahonda04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nahonda04 &raquo;</TD></TR><TR><TD CLASS="quote">i wanna see the dyno after you get them installed. i don't believe that they will make an addtional 15-23 whp, maybe 5-12 at most... if any at all!!
stage 2 cams ftmfw </TD></TR></TABLE>
i have to agree with you a little, but i got the cams spring and retainers for only $165, so if they only make 5hp it will be worth it....
Old Nov 6, 2008 | 02:54 PM
nahonda04's Avatar
Surje.motorsports
i have to agree with you a little, but i got the cams spring and retainers for only $165, so if they only make 5hp it will be worth it....</TD></TR></TABLE>see i was going to get dc5r cams originally because i was told they are about the same as stage 1 cams but then i founf out that the dc5r cams and the 05-06 type-s cams are almost the same.....so i decided to save for stage 2 cams+valvetrain kit!!
Old Nov 6, 2008 | 08:33 PM
brxtacy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nahonda04 &raquo;</TD></TR><TR><TD CLASS="quote">see i was going to get dc5r cams originally because i was told they are about the same as stage 1 cams but then i founf out that the dc5r cams and the 05-06 type-s cams are almost the same.....so i decided to save for stage 2 cams+valvetrain kit!!</TD></TR></TABLE>
yeah i agree, and in the future i will go with something like that, but now being a little short on cash, and for 165 bucks, i think its worth it
Old Nov 6, 2008 | 09:39 PM
02 i-vtec's Avatar
im running the buddyclub spec 3 cams, and its a ncie big improvement over stock...but it also depends on the tuner also.. i have a set of 05 type s cams if ur itnerested.. pm me
Old Nov 6, 2008 | 11:16 PM
brxtacy's Avatar
also from what i gathered on k20.org, the 05-06 intake is the almost identical but not the exhaust, it is different.....and it makes the most power to run a r intake cam and a tsx exhaust cam....
Old Nov 7, 2008 | 10:40 AM
nahonda04's Avatar
Surje.motorsports
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 i-vtec &raquo;</TD></TR><TR><TD CLASS="quote">im running the buddyclub spec 3 cams, and its a ncie big improvement over stock...but it also depends on the tuner also.. i have a set of 05 type s cams if ur itnerested.. pm me</TD></TR></TABLE>how long have you had them in? di you change the valvetrain? numbers?
Old Nov 7, 2008 | 11:01 PM
02 i-vtec's Avatar
put them in a few months back, im about to get it tuned in a week or so, but i did full buddyclub valve springs and retatiner with it
k powered ej1
Aug 20, 2007 10:31 PM
Meat_Wagon
Mar 6, 2006 01:28 PM
WH0R3nEF9
Feb 26, 2006 12:27 PM
MUGEN_B16CIVIC
12
Mar 27, 2004 07:49 AM
Big Teggie
Jun 16, 2003 02:31 PM
