Koni Yellow Rear Adjustment
Old Nov 4, 2008 | 06:37 PM
bopbop93030's Avatar
Default Koni Yellow Rear Adjustment
Do you have to remove the shock to adjust it or it is like the front just turn the know to adjust. I thought that u have to remove the shocks in the rear for it to have it adjusted.
Old Nov 4, 2008 | 08:49 PM
P_Adams's Avatar
Default Re: Koni Yellow Rear Adjustment (bopbop93030)
If there is no adjustment ****, you must fully collapse the shock's shaft until it bottoms. This will engage the adjuster mechanism and you can then twist the shaft to make your adjustment.
Personally, I went with KYB's to avoid just this &^%$
P
Old Nov 5, 2008 | 05:17 AM
TheMuffinMan's Avatar
He knows where you live!
What are you trying to adjust on it? The stiffness? I had to lower mine a bit to get access to the shaft, you should be able to use that white adapter on the top to turn it for stiffness. Because of the angle it's impossible to change it while bolted up.
So just remove the top bolts and swing it down a little bit and you should be good.
Old Nov 5, 2008 | 07:37 AM
Default Re: (TheMuffinMan)
This is what I am trying to avoid, it would be a pain to adjust it. It would be nice if its the same in the front.
I am looking for a shock that can handle more than 1.5 - 2in drop.
My illuminas can't handle it. It bottoms out after I cut my bump stop in half.
Old Nov 5, 2008 | 12:10 PM
It's not horrible, you're not going to be adjusting it on a daily or weekly basis. I'd go to the medium setting and see how you like it.
Old Nov 5, 2008 | 04:34 PM
How many settings does the rears have? and you think that the medium setting is good enough for DD or should I go stiffer or softer?
How important is the rears anyway, or is it the front that is important?
And can this shocks handle at least a 2-2.5" drop? I am not saying this is my drop right now, my car is around 1.75" from H&R sport but if I decide to go lower in the future will this shock handle it without bottoming out?
Thanks
Old Nov 5, 2008 | 04:39 PM
Two rings on the strut body.
Three technically by twisting the shaft.
Rear's can help oversteer or understeer tremendously. Stiffer rear w/ higher spring rates = more oversteer.
Old Nov 5, 2008 | 07:37 PM
so will this shock can handle 2 - 3" drop without bottoming out?
Old Nov 5, 2008 | 08:10 PM
Default Re: (bopbop93030)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bopbop93030 &raquo;</TD></TR><TR><TD CLASS="quote">so will this shock can handle 2 - 3" drop without bottoming out?</TD></TR></TABLE>
The Yellows? They did fine when I was slammed
Old Nov 6, 2008 | 08:56 AM
I decided to overhaul my suspension and get the yellow and GC. what would u suggest spring rate for DD. not to soft
Wsteun
Apr 28, 2008 12:10 PM
Killtodie
Honda Civic (2001 - 2005)
Dec 10, 2006 10:06 AM
SD_EM1
Jul 29, 2003 12:48 PM
SD_EM1
Jul 16, 2003 04:42 AM
siciliani
Feb 6, 2003 10:51 AM
