civic starts but stalls right away
hey guys, i tried searching but I didn't find anything good. i got a 96 civic lx with 180k miles, and lately i start it and it starts but stalls right away. after a couple of times it will get going.
any thoughts?
any thoughts?
It sounds like your getting spark i had the same problem in my car it would run fine and then all of a sudden die when i hit some bad bumps on the track and i checked my fuel and my spark had both and checked all my relays they were good. so i hooked the fuel pump up to a switch and it worked than alittle later in the week i noticed that when my roll cage was installed the ground hook up was undone and so my problem fixed GL
Main relay or ECU ground. There is a harness ground in the engine bay, depending on which motor you have but it should be near to the thermostat housing, if that is loose the car will start but would die once moved.
anyway, you have a Ground problem, a loose connection somewhere. check behind the dash and engine bay for all you ground points and tighten them up
Christopher Mai
18
Nov 16, 2016 03:11 PM
Jooleeus
13
Jul 20, 2008 08:46 AM
