Code 9 CYP is haunting me
Old Nov 4, 2008 | 05:31 AM
Nbboy7's Avatar
Default Code 9 CYP is haunting me
97 civic ex .I change the dizzy 3 times and reseted the ecu. Cel light still came back on. I got an other ecu same thing. I even hard wired they CYP to the ecu NO luck. Any help would be appreciated
Modified by Nbboy7 at 7:54 AM 11/4/2008
Old Nov 4, 2008 | 06:23 AM
Nbboy7's Avatar
help
Old Nov 4, 2008 | 06:44 AM
tuned2's Avatar
I have seen similar issues like this on the 99-00 Accords, and 96-00 Civics.. The diode in the alternator go bad, causing unwanted interference and setting code P1381. have your alt. checked. that is most likely where your problem is stemming from...
Modified by tuned2 at 8:46 AM 11/4/2008
Old Nov 4, 2008 | 06:46 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Code 9 CYP is haunting me (Nbboy7)
Help us help you:
Year/make/model of vehicle.
Does it have an engine swap? If so has it ever ran fine with no code 9?
Old Nov 4, 2008 | 06:56 AM
Nbboy7's Avatar
No swap It runs fine with no cels when i got cel it has a tiny sputer
Old Nov 4, 2008 | 07:04 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (Nbboy7)
You need to have an OBD2 scan tool hooked up and give us the actual P codes. Auto zone does this for free.
I suspect you might have a CKP sensor, not the CYP sensor being the problem, but the generic counting of the flashing light codes are not as descriptive as they need to be when it comes to OBD2 cars. If it's a CKF sensor it might throw a generic "code 9" if trying to use the two prong check method. The CKF senso is located in the oil pump, behind the lower timing cover and has nothing to do with the distributor.
This is just my suspicion...
Get it scanned, then report the actual P codes. I can personally help better with P codes.
Old Nov 4, 2008 | 07:14 AM
Nbboy7's Avatar
p1381
Old Nov 4, 2008 | 07:17 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Haha that's funny.
Well that's inside the distributor. No doubt. I just had a customer's 1998 Civic here yesterday with that exact code and we replaced the distributor with a Richporter Technology/Distributor King TD80 unit and it fixed the code and rough running.
However if you have already replaced the distributor (what kind though?) to no avail then it could be a wire/wiring or like the other guy stated maybe have a simple alternator/battery test done just to be sure it's not a low voltage issue.
Old Nov 4, 2008 | 07:19 AM
Nbboy7's Avatar
I used an 2oem and the an aftermarket from autozone
Old Nov 4, 2008 | 10:11 AM
Nbboy7's Avatar
help need to get it inspected
Old Nov 7, 2008 | 07:18 AM
holset b18c's Avatar
having the same issue in 2000 civic with gsr motor!! on the hunt for new distributors now!! maybe i will pick up a altanator now the be on the safe side!!
Old Nov 8, 2008 | 09:27 AM
tuned2's Avatar
any luck?
Old Nov 8, 2008 | 11:00 AM
Default Re: (tuned2)
wednesday i will have all my extra parts!! dizzy alterantor and starter!! so i will give you a update about my outcome!! if you have any luck let me know!! thanks
hugot231
Jul 7, 2010 02:32 PM
mattb145
Sep 17, 2008 05:01 PM
Ha Itz
Aug 9, 2007 07:30 AM
jetblack
May 16, 2006 06:20 PM
2stockrocketz
Mar 8, 2004 08:40 AM
