What intake are you running with your BPi stack(4th gen)?
Old Nov 3, 2008 | 11:13 PM
HdeucedeuceA's Avatar
Default What intake are you running with your BPi stack(4th gen)?
I have my stack on an ebay sri. The only problem I have with it, is the fact the intake has no mounting points to keep it at a fixed postion. I'm tired of going over a small bump and hearing the intake hit somthing.
So yeah, what are you guys using for a pipe with the stack on a 4th gen? My Injen sri wouldn't fit with it. I've seen a different Injen intake work but I don't know where to get it.
Old Nov 4, 2008 | 12:48 AM
H22Honda98's Avatar
Default Re: What intake are you running with your BPi stack(4th gen)? (HdeucedeuceA)
well my 5th gen i have mine on a CAI. my buddys 4th gen had about the same clearance though. CAI FTW
Old Nov 4, 2008 | 09:38 PM
Default Re: What intake are you running with your BPi stack(4th gen)? (H22Honda98)
It pisses like crazy here in Oregon, so I'm unsure if I want to go with a cai. H22's seem to like them but I'm sure they wouldn't like getting hydro locked.
Old Nov 5, 2008 | 05:40 AM
98vtec's Avatar
moderator emeritus
https://honda-tech.com/zerothread?id=1739826
https://honda-tech.com/zerothread?id=1814212
Old Nov 5, 2008 | 12:45 PM
Default Re: What intake are you running with your BPi stack(4th gen)? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1739826
https://honda-tech.com/zerothread?id=1814212</TD></TR></TABLE>
I've read both of those before. They'er all using ebay, cold air or custom ones. Not really what I was looking for. I want a sri that bolts to the chassis so it won't make a tick sound everytime I hit a bump; it's hitting my A/C line that's in front of the filter.
EDIT maybe I'll get the hack saw out again and take like an inch more off.
Old Nov 5, 2008 | 04:57 PM
ShoofIsLudin's Avatar
why don't u make a bracket??????
go to homedepot, or lowes, get some metal straps...bend around ur intake, and drill holes in the strap so it mounts to a local bolt in the engine bay
Even if u cut ur intake shorter...its not gonna stop it from bouncing around like its doing now.....
Old Nov 5, 2008 | 05:30 PM
H22Honda98's Avatar
Default Re: (ShoofIsLudin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HdeucedeuceA &raquo;</TD></TR><TR><TD CLASS="quote">It pisses like crazy here in Oregon, so I'm unsure if I want to go with a cai. H22's seem to like them but I'm sure they wouldn't like getting hydro locked.</TD></TR></TABLE>you arent going to hydrolock your engine unless you drive through one hell of a puddle. especially with splash shields.
ArmaanOG
Aug 3, 2009 08:41 AM
helicopter201
Aug 7, 2006 02:14 PM
AndyD
Jan 19, 2004 07:01 PM
Sephro
Aug 31, 2002 11:24 AM
