NO VTEC!!!!!
Old Nov 3, 2008 | 10:26 PM
philosofy1's Avatar
Default NO VTEC!!!!!
i currently have a 93 hatch w/ a B16A (obd1). i recently changed the oil pan because the threading where the drain bolt goes was stripped.
after changing the pan i noticed that the oil light on the dash stays on alittle longer after i start the car.
now i know oil pressure can affect vtec, but how can me changing the pan affect this, why would this happen?
Old Nov 3, 2008 | 10:34 PM
slo_hatch's Avatar
Default Re: NO VTEC!!!!! (philosofy1)
maybe your losing some psi because its not sealed good?? thats about the only reason i can think of...
Old Nov 3, 2008 | 10:38 PM
95lscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">i currently have a 93 hatch w/ a B16A (obd1). i recently changed the oil pan because the threading where the drain bolt goes was stripped.
now i know oil pressure can affect vtec, but how can me changing the pan affect this, why would this happen?</TD></TR></TABLE>
any codes? if there isn't a code your ecu shouldn't be turning off vtec. if there is then often times your car will shut it off to simply protect itself. like stated before me the only possibility is lack of oil pressure but i can't really see that happening.
white_crx_guy
Apr 4, 2007 03:44 PM
ATS*Mark
48
Feb 11, 2007 03:45 PM
roc
Jun 13, 2006 09:37 AM
specialedition
Sep 16, 2004 08:41 AM
sikek
Aug 10, 2004 05:49 PM
