replaced axel still vibration? any ideas
Old Nov 3, 2008 | 09:16 PM
boostEG6's Avatar
Default replaced axel still vibration? any ideas
Car is a 1997 dx hatch, recently replaced the passenger side axel because of torn boot in orginal. Replaced with a pepboys one , Now seems like the car is pulling more to the right as well as more of a steering wheel vibration then before? Tire tread is near new wheel is balanced aswell .. I've been told these aftermarket axels even though new are still refurbished so this may be my problem? If not any sugguestions please. Car is lowered on h&r sportspring/kyg shocks
Old Nov 3, 2008 | 09:39 PM
yoontim23's Avatar
Default Re: replaced axel still vibration? any ideas (boostEG6)
Check out your motor mounts.
Old Nov 3, 2008 | 09:56 PM
2FastxEg's Avatar
has the car ever been in a slight car accident? if so, the car's frame needs to be straightened out.. this is quite common on cars that have been in a small accident(or big one)..... if you turn on the AC, does it vibrate even more? if it does, then you need the frame straightened out.
Old Nov 3, 2008 | 10:54 PM
mattyv's Avatar
ball joints?
Old Nov 3, 2008 | 11:19 PM
EKtypeRhaTcH's Avatar
could be ball joints or wheel bearings. My wheel bearings were so bad that it messed up the hub, so i had to replace that too. Also could STILL be the axle, even though you changed the boot, the joint could still be bad from all the dirt that got in.
Old Nov 4, 2008 | 01:32 PM
poboycustoms's Avatar
Default Re: (EKtypeRhaTcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKtypeRhaTcH &raquo;</TD></TR><TR><TD CLASS="quote">could be ball joints or wheel bearings. My wheel bearings were so bad that it messed up the hub, so i had to replace that too. Also could STILL be the axle, even though you changed the boot, the joint could still be bad from all the dirt that got in.</TD></TR></TABLE>
+1
Old Nov 4, 2008 | 03:13 PM
blankslat5's Avatar
i had to get 3 axles in a row from pep boys until i found one that stopped vibrating. they suck spend the extra money and get a honda one. they dont balance the axles. could be your ball joints though
Old Nov 4, 2008 | 03:29 PM
vTac_hedge's Avatar
It seems like that axle you got is not balanced. At what MPH does it start shaking?
Old Nov 4, 2008 | 03:41 PM
1992Si's Avatar
Default Re: replaced axel still vibration? any ideas (blankslat5)
I've done 4 in a 91DA before I got a good one.
Spend the money and buy a better quality axle.
Old Nov 4, 2008 | 06:38 PM
boostEG6's Avatar
It vibates at slow speeds aswell as highway also pulling to the right more then it was before, you can see the steeringwheel shaking more then it was before but I mean you can just feel it all on the right side . I tried to rotate tire to make sure it wasnt jus that one but ya same thing. I appreciate everyones input on this!!! Also.. Am I going to be able to return this axel to pepboys even though Ive already installed and driven it.. even though it may be there axel that sux?
Old Nov 5, 2008 | 05:35 AM
blankslat5's Avatar
Default Re: (boostEG6)
just as long as you have the receipt you should be fine just return it and tell them that the axle was not balanced and exchange it for another one they shouldnt give you a problem
Old Nov 5, 2008 | 05:42 AM
Black96Hatch's Avatar
look man i work at pepboys and goin there for parts is ur first mistake lol get oem
Old Nov 5, 2008 | 05:56 AM
jeremyrocksursox's Avatar
Default Re: replaced axel still vibration? any ideas (Black96Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black96Hatch &raquo;</TD></TR><TR><TD CLASS="quote">look man i work at pepboys and goin there for parts is ur first mistake lol get oem</TD></TR></TABLE>
x2
Old Nov 5, 2008 | 06:00 AM
fryguy190's Avatar
Default Re: replaced axel still vibration? any ideas (jeremyrocksursox)
it sounds like u need an alignment as well but deffinetly buy a better axle first.
cbaber
Aug 22, 2024 04:47 PM
b20bFourDoorCivicLX
Mar 7, 2012 06:26 PM
buzlink
16
Oct 18, 2007 07:41 PM
uneek4dr
Apr 24, 2006 01:12 AM
jizno
Nov 23, 2005 01:57 PM
