Clutch squeek???
So whenever im in first and startting to get my car going i hear this loud squeeking noise.. and i think its coming from the cluch??? anyone out there with this issue before?
mine does, as well as many others when you push the clutch down... its very common and the solutions (when I searched) were various and not too consistent with most just dealing with it.
if its a different squeak, sorry =/
Yep, sounds like the symptoms of a throw-out bearing. I had that problem in my BB6. But since I was taking down the tranny I replaced my clutch for an Exedy stage 2 and a 8lbs. Fidanza flywheel. I suggest you do that while the tranny is down!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Since 1983 »</TD></TR><TR><TD CLASS="quote">input shaft bearing?</TD></TR></TABLE>
They don't squeak, generally more of rough bearing noise, I don't really know how else to describe it, but its definately not a squeak. To the OP. the pedal itself may be squeaking where it pivots.
Is it kinda like a Shriek? Mine does that too if so. Like pull the ebrake up and try to move it forward. I think its the flywheel heated up. Might need a resurface.
RubenPrelude
Jun 22, 2007 04:07 PM
katb16vo
Apr 24, 2004 06:04 AM
