92 Prelude F22a1 Swap to F22B2
Old Nov 3, 2008 | 05:52 PM
jaybaisley's Avatar
Default 92 Prelude F22a1 Swap to F22B2
F22a1 Blew up so im trying to swap in a F22B2 out of a 95 accord used most of the sensors and the intake manifold from the A1 and i am having trouble with Fire and Fuel Any suggestions
Old Nov 4, 2008 | 06:02 PM
jaybaisley's Avatar
Default Re: 92 Prelude F22a1 Swap to F22B2 (jaybaisley)
Latest Progress ;
Fuel Pressure in the fuel rail
can get fire on one plug
all plugs remain dry even without fire
any help appreciated
Old Nov 5, 2008 | 07:31 AM
Prelude_1992's Avatar
its a pain in the ***
i did it, and everything was cool the car does run
but im throwing vtec, map, and tp sensor codes
and its in limp mode.
absolutely no one knows what to do.
Old Nov 5, 2008 | 09:12 AM
jaybaisley's Avatar
Default Re: 92 Prelude F22a1 Swap to F22B2 (Prelude_1992)
did you have any of the same problems i had or no ?
Old Nov 6, 2008 | 10:47 AM
jaybaisley's Avatar
did you have any of the problems i had ie. spark fuel etc. ?
Old Nov 6, 2008 | 10:53 AM
F22B1Prelude's Avatar
check your engine wiring harness grounds.
Old Nov 6, 2008 | 04:47 PM
jaybaisley's Avatar
Default Re: 92 Prelude F22a1 Swap to F22B2 (F22B1Prelude)
i have cleaned all the ground contacts in the engine bay that was the first thing that came to my mind when the problem started, there is good spark coming from the coil and only one terminal from the distributor cap is producing spark, i cleaned all the points inside the cap and the contact on the button but the problem seems to be something else, whatever it is is beyond my knowledge and i cant seem to figure it out, but i greatly appreciate your response thank you
Old Nov 10, 2008 | 05:17 PM
jaybaisley's Avatar
solved the fuel problem we think does anyone have any idea what would cause it to fire on one cylinder have tried 2 different coils and 3 different distributors
Old May 25, 2011 | 06:07 AM
bclemm80's Avatar
does anyone know if its possible to put a f22b2 swap into a 96 prelude shell? will the mounts match or i have to transfer those over too if its possible?
famdakam
Honda Civic (2006 - 2015)
Feb 8, 2017 05:19 PM
CivicCpeEX
Jul 11, 2010 07:59 PM
91highryda
Feb 11, 2007 06:35 PM
GhostInTheShell
May 30, 2006 02:31 PM
