Beeping after new ignition column install
Old Nov 3, 2008 | 02:51 PM
alacard's Avatar
Default Beeping after new ignition column install
Long story short: Thieves broke ignition column (99 civic hatch), bought a used one off of NOFX/Eran and replaced the broken one with the used one. Everything is perfect other than one small annoyance. The beeper for a key being left in your ignition goes off no matter what when I open the door. In other words, if my key is in my hand (not in the ignition) and I open the door, it will beep. Also, the beep for leaving your headlights on (which I believe is a different tone all together) does not go off when I open the door with headlights on. Any ideas?
Thanks in advance.
Edit: Please don't tell me to simply disconnect the beeper or whatever. I would like to fix the problem, not cover it up. Thanks.
Old Nov 3, 2008 | 09:51 PM
alacard's Avatar
Default Re: Beeping after new ignition column install (alacard)
bump for some help
Old Nov 3, 2008 | 10:50 PM
Davus's Avatar
The headlight beep won't occur since it's pre-occupied with "key in ignition" beep. I've been getting this issue intermittently on my 96, somehow moving the key around in the ignition slot while removing makes it go away. Does yours -always- occur, and is there any way to make it go away?
Old Nov 3, 2008 | 10:59 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
Never heard of that happening until this thread. Wish I could help you out.
Old Nov 4, 2008 | 09:08 PM
alacard's Avatar
Default Re: (Davus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davus &raquo;</TD></TR><TR><TD CLASS="quote">The headlight beep won't occur since it's pre-occupied with "key in ignition" beep. I've been getting this issue intermittently on my 96, somehow moving the key around in the ignition slot while removing makes it go away. Does yours -always- occur, and is there any way to make it go away?</TD></TR></TABLE>
Yeah, that is what I assumed was going on. Nope, unfortunately it isn't intermittent. It beeps every time the door is open regardless of the key position.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">Never heard of that happening until this thread. Wish I could help you out. </TD></TR></TABLE> Thanks, hopefully someone has.
Old Nov 5, 2008 | 06:43 PM
SIRll-EK's Avatar
if your car came from Canada it will have a negative keysense wire that will be blue/white or blue /red ..... it needs to rest at 12 volts and drop to zero when you put the key in..... if its not seeing a ground it will think the keys in the ignition .... so if you have a ignition out of a USDM car the key sense wire wont be there and the beeper will keep going off ..... this is just a idea i hope this helps
Old Nov 5, 2008 | 08:34 PM
alacard's Avatar
Default Re: (SIRll-EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRll-EK &raquo;</TD></TR><TR><TD CLASS="quote">if your car came from Canada it will have a negative keysense wire that will be blue/white or blue /red ..... it needs to rest at 12 volts and drop to zero when you put the key in..... if its not seeing a ground it will think the keys in the ignition .... so if you have a ignition out of a USDM car the key sense wire wont be there and the beeper will keep going off ..... this is just a idea i hope this helps </TD></TR></TABLE>
Where would this wire be? How would I track this down? thanks for the help.
Old Nov 5, 2008 | 08:56 PM
Eran's Avatar
HT White Ops
WOW. That is awesome. Great tech info.
This is quite possibly the best first post I have ever seen. You are a credit to this site and a shining beacon of hope for all the other retarded '08 members.
Good form, and welcome to the site.
Old Nov 7, 2008 | 01:18 PM
alacard's Avatar
Old Nov 8, 2008 | 05:08 PM
SIRll-EK's Avatar
Default Re: (alacard)
heres a pic ..... thanks for the props .... i'm a 12 volt installer so i try to help when i can
http://www.directechs.com/timages/ksense_20985.jpg
Old Nov 8, 2008 | 11:55 PM
alacard's Avatar
Thanks man, but the link didn't work for me
Old Nov 9, 2008 | 09:33 AM
NOFX's Avatar
H-T White Ops
Brings me to their main page.
Old Nov 9, 2008 | 04:15 PM
SIRll-EK's Avatar
Default Re: (NOFX)
oops i forgot my computer automatically sets up the password .... i'll do it the ghetto way
Old Nov 9, 2008 | 04:28 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
So that's supposed to be a '99-'00 keyless module then, right? '96-'98 should be in the radio.
Old Nov 9, 2008 | 04:35 PM
SIRll-EK's Avatar
Default Re: FV-QR (NOFX)
yep .... he said he had a 99 ...... this is a pic from a Canadian model .... if thats the problem it'll look like the pic
Old Nov 9, 2008 | 09:01 PM
alacard's Avatar
Excuse me for my stupidity, but what is it that I would need to check/do to try to fix this?
I really do appreciate the help so far.
Old Nov 9, 2008 | 10:01 PM
NOFX's Avatar
H-T White Ops
Default Re: FV-QR (SIRll-EK)
USDM hatchbacks didn't have keyless either though. They were all built in Canada, but they're not really much (if at all) different then the US built and Japan built ones.
Old Nov 10, 2008 | 04:09 AM
SIRll-EK's Avatar
Canadian cars are a little different because of there immobilizer laws they have.....
thats why a canadian model will have a keysense wire and usdm ones dont... if theres no keyless model you can look in the green factory alarm plug for the keysense .....
i'm just trying to help a guy out not start a argument ..... if i'm wrong i apologize
Old Nov 10, 2008 | 08:58 AM
NOFX's Avatar
H-T White Ops
I'm not arguing either.
I was under the impression that his car was just built in Canada (like all US hatchbacks), not "from" Canada.
Old Nov 10, 2008 | 02:10 PM
alacard's Avatar
Correct.
Someone help me with my complete confusion! haha.
Old Nov 11, 2008 | 01:13 PM
alacard's Avatar
Default Re: FV-QR (alacard)
Old Nov 12, 2008 | 05:55 PM
SIRll-EK's Avatar
heres what i would do ..... first check to see if the keysense wire is there ... if it's not ...it's not your problem
.... if it is to fix it correctly you are gonna need a Canadian column ..... i'll do some research to see what else it could be
Old Nov 12, 2008 | 09:11 PM
alacard's Avatar
I just realized I don't even have a harness/plug in the kick panel right there because my car is a dx hatch.
Old Nov 13, 2008 | 02:15 PM
alacard's Avatar
Any other ideas? This is a huge annoyance. Especially when I'm working on my car and I need to have the door open.
Old Nov 13, 2008 | 06:59 PM
alacard's Avatar
