my 89 EF HB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cetcivic »</TD></TR><TR><TD CLASS="quote">IM GONNA NEED A MICROSCOPE BUDDY
Try clicking the pictures.
</TD></TR></TABLE>Try clicking the pictures.
ya sorry i guess it from using the url form myspace. you just have to click on them. i just got the motor in last night. it will be on the road today and i'll get some better BIGGER pics tonight
don't mind the mess of a shop. . .
Modified by EF_EJB16A at 7:21 AM 11/4/2008
finally got it done! i need to get my camera i took these with my phone and it was raining so there is EFING glare coming off everything
here is a list over everything done
engine :
SRP CTR pistons
Eagle H beam rods
Eagle crank
ARP main studs, rod bolts and head studs
acl race bearings
CTR crank pulley
skunk 2 pro2 intake mani
blox 70mm throttle body
APEX'I header
2.5 OBX cat back
stage 3 ACT clutch and 9 LBS fly wheel.
B16 trans
interior:
CRX dash
half cage.
stock honda CD player. . . not sure what from i found it in the house im buying with the plugs and the code wrote on the back
send picks of it soon
disk brakes all the way around
with first gen GSR rims black
Modified by EF_EJB16A at 10:18 PM 11/8/2008
Modified by EF_EJB16A at 1:47 PM 11/9/2008
engine :
SRP CTR pistons
Eagle H beam rods
Eagle crank
acl race bearings
CTR crank pulley
APEX'I header
2.5 OBX cat back
B16 trans
interior:
CRX dash
half cage.
send picks of it soondisk brakes all the way around
so i blew my b16 the first day i got it on the road with in about 2 mins. . . .
its got an ls in it now.
im pulling the motor apart probably monday. i'll see what happens
i had 2 sitting around. the one in my car was one i put in my DB8 shell so my wife had something to drive. i think i pinched a bearing in the b16. the rotating assembly spun freely until i torqued down the rod caps, it seemed like it was a little too stiff after that. i shoud have gauged them. we have ran the same bearings before without do it but we have never used forged internals. now i know better. . . expensive lesson
whooa ouch that cuts really deep, ***. what a waste of space you are and im sure your moms geo metro is clean as ****. so if thats all you have to say about my car then the next time you want to open your mouth let me know so i can stuff my nuts down your throat. oh and since we are coming up with such original cut-downs, i'll make you choke on my nuts AFTER I **** your mom, just to clear that up. put that in your pipe and smoke it, bitch
