Suspension & Brakes Theory, alignment, spring rates....
Ground Control sleeve bolt stripped
Old Nov 3, 2008 | 02:20 PM
Xathine's Avatar
Default Ground Control sleeve bolt stripped
I was trying to raise my car up the other day, and all 4 of the bolts on my GC sleeves were corroded. As soon as I put the key in and turned the least bit it stripped each bolt.
I cannot loosen my sleeves. The GC sleeves themselves are but only a few months old - what gives?
Is this covered under GC warranty? I emailed them but haven't heard back from them. What could I do to fix this?
Old Nov 4, 2008 | 11:34 AM
Xathine's Avatar
Default Re: Ground Control sleeve bolt stripped (Xathine)
no one?
Old Nov 4, 2008 | 11:51 AM
hawjboi's Avatar
try using an extractor of some sort...i had one that seized on me and couldn't get it out so i drilled it out and called gc and bought a new collar...i think they were like 20 bucks each...if you can get them out with out ruining the threads use anti-seize so you wont have that problem next time...
Old Nov 4, 2008 | 03:11 PM
Tyson's Avatar
ive never had this problem.
i dont torque the bolt down much either...
drill it out or cut it out.
Old Nov 6, 2008 | 12:51 PM
Xathine's Avatar
Default Re: Ground Control sleeve bolt stripped (Tyson)
yeah it wasn't torqued down much, and I had anti-seize on it
JDM_Ej
Suspension & Brakes
22
Dec 16, 2011 08:20 AM
super_nguyen
Suspension & Brakes
May 30, 2006 02:02 PM
PA MATT
May 5, 2004 06:54 AM
atisvt99
Jan 21, 2004 08:03 AM
sbrocks1
Mar 14, 2002 04:24 PM
