my vtec hesistates. do i have a bad tune?
Old Nov 3, 2008 | 12:26 PM
civicekgsr99's Avatar
Default my vtec hesistates. do i have a bad tune?
i have a 99 civic si and i bought it with a jdm b18c swapped in it already. it has a few internals such as high compression pistons and cams so the guy who had it before me said he had it tuned at a shop. the vtec doesnt crossover clean. it hesitates a few seconds and then starts to pull again. is there a problem with the tune or could it be something else?
Old Nov 4, 2008 | 09:32 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: my vtec hesistates. do i have a bad tune? (civicekgsr99)
my guess would be low oil pressure..
Old Nov 7, 2008 | 07:10 AM
Default Re: my vtec hesistates. do i have a bad tune? (sanimalp)
if i dont have an oil pressure gauge how could i test if thats the problem?
Old Nov 7, 2008 | 07:40 AM
Relic1's Avatar
datalog the event to see what the ECU is thinking/doing.
Old Nov 9, 2008 | 07:04 PM
srmofo's Avatar
buy a oil pressure gauge
Old Nov 25, 2008 | 12:36 PM
thanks for your help lol
Old Nov 26, 2008 | 02:19 PM
Zxspyderz01's Avatar
yeah id buy a guage. I used autometer gauge in mine converts the mechanical signal to electrical so dont have to worry about an oil line cracking and what not inside the car. Being able to constantly see the oil pressure is a definete plus! Gauge only about 50 bucks well worth it and takes about 45- 1 1/2 to install at most!
Old Nov 28, 2008 | 12:36 AM
king06's Avatar
I'd say unplug it an make sure its vtec an not something else. I'm having the same problem on a turbo gsr, i'll unplug mine today.
Old Nov 28, 2008 | 05:22 AM
GSR_hatch936's Avatar
Did it aways do that? Cuz i know that if ur oil level is low it will either hesitate or just not even engage.
Old Nov 28, 2008 | 05:31 AM
Paul-R's Avatar
I ran into the same problem with my Ls/VTEC it lagged when it reached the kick in spot so i couldn't find out what it was so i decided to take it back apart and then that's where i found the problem 2 of my intake valve stems were cracked due to off rounded lobes on the cam shaft causing my intake to stay closed for a few seconds before it was forced to open so i rebuilt the internals now it works just find ... Oil pressure will not cause excessive VTEC lag . So all in all my air speed was insufficient. That is what my problem was i hope it aint he same for you .
Old Dec 2, 2008 | 04:00 PM
yea it has since i bought the car a little more than six months ago. i have changed the oil and stuff and made sure the level is always right.
Old Dec 2, 2008 | 04:20 PM
miller's Avatar
I would go with tune.
Old Dec 2, 2008 | 04:52 PM
drtysohc's Avatar
I had the same problem, then my oil pump took a ****. 4 chewed up main bearings isn't a pretty sight.
Old Dec 3, 2008 | 05:54 AM
mtber's Avatar
+2
superhatchbackbros
Jul 28, 2006 05:47 PM
PaImportTuner
Aug 13, 2005 11:17 AM
