sport mode light on
If the Speedometer still works, the ECM hasn't set a code and the Transmission appears to be operating correctly, more than likely the TCM bought the farm.
If the VSS (Vehicle Speed Sensor) had failed; the "Check Engine Lamp" would be lit and the speedo would be sitting there staring back at you.
P
P
Your TCM is located here: Bronze box on the right.
P
91POSAccord
Mar 12, 2007 06:54 PM
