How do I remove the stock radio for '99 Prelude?
Old Nov 3, 2008 | 07:04 AM
Lovemy99Lude's Avatar
Default How do I remove the stock radio for '99 Prelude?
Can anyone help me with this? Is it a long and painful process? If you are able to show steps in pictures that would be a plus!
Old Nov 3, 2008 | 07:55 AM
iwanttokillgod's Avatar
Default Re: How do I remove the stock radio for '99 Prelude? (Lovemy99Lude)
it takes two seconds the black plastic trim pops off and its screwed in by for screws
Old Nov 3, 2008 | 09:25 AM
Default Re: How do I remove the stock radio for '99 Prelude? (iwanttokillgod)
ok, but where is the safest place on the trim to pry a part so I dont break it?
Old Nov 3, 2008 | 10:19 AM
charlie0801's Avatar
take two small flathead screwdrivers with a cloth(so you dont scratch the trim) and pry away from the console from the inside side sections
Old Nov 3, 2008 | 12:31 PM
TooSunny's Avatar
New User
i will like to know this too.
Old Nov 3, 2008 | 07:01 PM
Default Re: How do I remove the stock radio for '99 Prelude? (TooSunny)
OK! It was easier than I thought. It took only a few seconds to remove the trim, them unscrewed four screws (two on each side). Thanks guys.
Old Nov 3, 2008 | 07:08 PM
VtecPrelude95's Avatar
Default Re: (charlie0801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charlie0801 &raquo;</TD></TR><TR><TD CLASS="quote">take two small flathead screwdrivers with a cloth(so you dont scratch the trim) and pry away from the console from the inside side sections</TD></TR></TABLE>
Plastic panel tools is the best way. available at your local tool store
Old Nov 3, 2008 | 07:42 PM
dagle's Avatar
Default Re: (VtecPrelude95)
i use a box cutter just to pry the edge out a bit so i can get my hands on it. haven't damaged anything yet
Old Nov 4, 2008 | 05:19 AM
Default Re: (dagle)
The flat heads worked perfect without any scratches. I got the security code and took it to the dealership this morning...now my radio works again, finally!
93CamaroLT1
Sep 12, 2008 03:36 AM
sheekdude
Acura TL, RL & ZDX
Nov 10, 2006 03:36 AM
fubar
Jun 12, 2004 01:42 PM
STN_Pat
19
Apr 5, 2004 02:49 PM
JG99
Nov 5, 2002 01:01 PM
