wet sand paper or reg sandpaper for polishing rims?
Old Nov 3, 2008 | 12:16 AM
dshiromoto's Avatar
Default wet sand paper or reg sandpaper for polishing rims?
says in the title
Old Nov 4, 2008 | 01:46 PM
hazard2o9's Avatar
Default Re: wet sand paper or reg sandpaper for polishing rims? (dshiromoto)
wet
Old Nov 6, 2008 | 02:03 PM
forced97's Avatar
WET!!!!!
Old Nov 6, 2008 | 04:59 PM
jakeiscool's Avatar
Banned
Default Re: wet sand paper or reg sandpaper for polishing rims? (forced97)
3m wetordry works great. finish with some #00 Steel Wool then final polish. Honestly that german stuff called Flitz works great.
Old Nov 9, 2008 | 02:44 PM
tilegend's Avatar
regular dry sandpaper rarely goes up high enough in grit size that you'll need to polish metal. even though 3m makes the wet/dry sandpaper its better to use wet anyways because you use water as a lubricant and it carries away the particles that would otherwise clog up the sandpaper and make it useless after a few strokes.
depending on the condition of the wheels i'll start with 600 wet and work my way all the way up to 2000, wet also
then i'll use buffing compounds, tripoli (brown) and then white rouge and finish up with a polish.
Old Nov 12, 2008 | 05:28 PM
ejLday's Avatar
Originally Posted by dshiromoto
says in the title
both try searching there is a great write up on how to do it right
B18CivicEH2
Paint and Body
Apr 25, 2007 10:18 AM
96civicHATCH
Audio / Security / Video
Feb 24, 2006 11:58 AM
jetpilot
Mar 16, 2004 06:04 PM
Lei Siew Long
Mar 6, 2004 12:55 PM
LudemanDan
Oct 13, 2002 05:35 PM
