Hawk HP Plus brake noise
anyone used Hawk HP Plus brake pads?
I just replaced my rotors and pads, got the cheapest $30 rotors from Smyth Automotive, and Hawk Pads. They work great except from 10 mph to 0 mph. They make a harsh grinding noise, i have seated the pads twice now and am still getting the grinding.
Very Annoying, need help.
Thanks
Thanks
any ideas on how long the break-in period is? I have roughly 100 miles on them. I believe I have narrowed the noise down to the outside of the rotor on the drivers side.
Burnishing Instructions
After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
DO NOT DRAG BRAKES!
Allow 15 minutes for brake system to cool down.
After step 4 your new pads are ready for use.
DO NOT DRAG BRAKES!
Hi no the squeal...they are squealers....I know some have had some quiet sets but I have not. Had them 3 times and they always made some type of noise...grinding , squealing , dusty , eat rotors , totaly great
theres a possibility that the pad material causes it to make more brake dust and squeek. but id go over ur brakes. make sure u have lubricant on it all. also if you have to, this is last resort put a slit down the middle of them if there solid
Shakes
May 8, 2005 02:54 PM
