intermediate shaft...
Old Nov 2, 2008 | 02:46 PM
NightHawkBlack-R's Avatar
Default intermediate shaft...
I recently put new axles in my 01 type r and i keep smelling tranny fluid, once i jacked the car up i noticed there was tranny fluid leaking slowly from the intermediate shaft. Can i just get a new bearing or will i have to get a whole new shaft?
Old Nov 2, 2008 | 03:23 PM
jomama's Avatar
what makes you think it's something with the intermediate shaft as opposed to something with the tranny or maybe something's just not installed/fitted correctly?
Old Nov 2, 2008 | 04:18 PM
Bbasso's Avatar
Default Re: intermediate shaft... (NightHawkBlack-R)
Uhh?
detail, more details please to help solve the problem.
Old Nov 2, 2008 | 10:38 PM
The reason i think its the intermediate is because it's there's a liquid substance leaking from the shaft and i believe its tranny fluid. Do i need to take it back out and make sure the axle is installed correctly or is something wrong with the shaft?
Old Nov 2, 2008 | 10:44 PM
neo_'s Avatar
There is no fluid in the intermediate shaft. If it is leaking in between the transmission and intermediate shaft, then replace your axle seal. If it is leaking in between the intermediate shaft and the axle, then you probably just spilled something on it, or it is getting dripped on by another source.
Old Nov 2, 2008 | 10:53 PM
Default Re: intermediate shaft... (neo_)
Thanks
Old Nov 3, 2008 | 03:31 AM
irev210's Avatar
have fun replacing that seal. It is a pain to swap out when the motor is in the car.
Old Nov 3, 2008 | 03:34 AM
walker111's Avatar
Default Re: intermediate shaft... (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">have fun replacing that seal. It is a pain to swap out when the motor is in the car.
No its not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">There is no fluid in the intermediate shaft. If it is leaking in between the transmission and intermediate shaft, then replace your axle seal. If it is leaking in between the intermediate shaft and the axle, then you probably just spilled something on it, or it is getting dripped on by another source. </TD></TR></TABLE>
Exactly. Get an oil change recently? Oil will leak down from the oil filter. Also check to make sure the black box is not leaking.
1320london
Transmission & Drivetrain
Feb 1, 2015 10:02 AM
blackeg
Nov 19, 2004 03:22 PM
Black 2K
Jul 24, 2003 02:28 AM
