Revved to 9300rpm and i think i broke sumthan...
Old Nov 2, 2008 | 07:45 AM
T3KNiQe's Avatar
Default Revved to 9300rpm and i think i broke sumthan...NEED HELP!!!
I got a b16a1 with civic type R cams with stock valves an springs an **** and AEM camm gears. On top of the usual mods i got a skunk2 chip put'n vtec at 4900 rpm. Jus the other night i revved it to 9300 for the first time (ive revved to 9k before) and now things sound "funny"...I hear all this loud clattering in the engine bay and it sounds like its all clattering up in the head of the engine sumwhere. ALSO my exhaust (apex'i gt) does sound diifferent kinda lil muffled if you know what i mean..SO WHAT DID I BREAK?!?!?!?!?!?!?!?!?!?!?!?!?!? All responses most appreciated.
Old Nov 2, 2008 | 07:54 AM
civicjoe's Avatar
Default Re: Revved to 9300rpm and i think i broke sumthan...NEED HELP!!! (T3KNiQe)
Do a compression test and post up the results.
I'm not a pro but I think you could have floated a valve and it got hit by a piston.
Old Nov 2, 2008 | 08:01 AM
wrenchez81's Avatar
Default Re: Revved to 9300rpm and i think i broke sumthan...NEED HELP!!! (civicjoe)
x2^^
Old Nov 2, 2008 | 08:12 AM
T3KNiQe's Avatar
Thats what im stessin right now cause with CTR cams and stock valves im thinkin thats what happened...cause the engine sounds like thiers no oil in it when it runs
Old Nov 2, 2008 | 08:14 AM
T3KNiQe's Avatar
*stressin
Old Nov 2, 2008 | 08:30 AM
wrenchez81's Avatar
when was the last time the valves were adjusted????
Old Nov 2, 2008 | 08:37 AM
.Hookedonhatch.'s Avatar
Default Re: Revved to 9300rpm and i think i broke sumthan...NEED HELP!!! (wrenchez81)
I think you might'a brok'd sumthan wan u hit'd mad vtak shif'n outta 3rd ger @ 9300..
Do a compression test and stop chillen with vin racing ferrari's, **** becomes expensive.
Old Nov 2, 2008 | 08:54 AM
T3KNiQe's Avatar
Default Re: Revved to 9300rpm and i think i broke sumthan...NEED HELP!!! (.Hookedonhatch.)
Ill do the compression test but you guys think its just damage to a valve or sum valves? Or is the piston damaged also? I wanna kno as much before i start taking things apart THIS HAS NEVER HAPPENED TO ME BEFORE, SO I WANNA KNOW EVERYTHING PEOPLE HAVE TO SAY!!!
Old Nov 2, 2008 | 08:56 AM
wrenchez81's Avatar
is the engine misfiring at all???? again when was the last time the valves were adjusted????
Old Nov 2, 2008 | 04:19 PM
jasony0630's Avatar
76.26.106.124
haha
/owned
Old Nov 2, 2008 | 05:44 PM
Panda_slicks86's Avatar
help us or we cant help you do a damn comp test that will clear things up some for us to help u
Old Nov 2, 2008 | 07:18 PM
dynimitejack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3KNiQe &raquo;</TD></TR><TR><TD CLASS="quote">I got a b16a1 with civic type R cams with stock valves an springs an **** and AEM camm gears. On top of the usual mods i got a skunk2 chip put'n vtec at 4900 rpm. Jus the other night i revved it to 9300 for the first time (ive revved to 9k before) and now things sound "funny"...I hear all this loud clattering in the engine bay and it sounds like its all clattering up in the head of the engine sumwhere. ALSO my exhaust (apex'i gt) does sound diifferent kinda lil muffled if you know what i mean..SO WHAT DID I BREAK?!?!?!?!?!?!?!?!?!?!?!?!?!? All responses most appreciated. </TD></TR></TABLE>
Well your first problem is your an Idiot. I'm sorry but its true. I vote this thread Fail of the Year.
Ahh, I really thought this was a joke, If you would have taken 6 seconds to check wikipedia.org you would have seen that the redline on a B16A1 is 8200 rpm not 9300 and no matter what the guy that sold you the "skunk 2 chip" said you engine doesn't make power after 8k rpm. There are so many different problems you could have caused.
For example:
Timing belt skipped a tooth and now your valves are making out with your pistons.
Bent valve
Broken valve
Broken valve spring
Cracked/ broken rings
Holy pistons
On top of those possible problems theres a good chance that you warped the head.
I think you broke sumthan too.
Old Nov 2, 2008 | 07:28 PM
Garage 808 Hatch's Avatar
or you may have had something in the valvetrain loosen up.
check the timing alignment first, then do a valve adjustment and see if you have some loose clearances. may possibly have destroyed the LMA's as well
Old Nov 2, 2008 | 07:43 PM
brian22's Avatar
do a leak down test and it will show it there if any valves are bent and where and yeah your lucky you didnt spin a bearing at 9000
Old Nov 2, 2008 | 08:01 PM
sintype's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynimitejack &raquo;</TD></TR><TR><TD CLASS="quote">
For example:
Bent valve
Broken valve
Broken valve spring
Holy pistons
i agree. why rev to 9300? hahaha.
Old Nov 2, 2008 | 08:04 PM
iamthefollower's Avatar
Default Re: Revved to 9300rpm and i think i broke sumthan...NEED HELP!!! (dynimitejack)
I think you just floated a valve, because if it has went to 9k rpms before then it shouldn't have done too much.. it is probably just stressin the engine and everything.. do the leakdown test and check the valves..
Old Nov 2, 2008 | 08:05 PM
Default Re: Revved to 9300rpm and i think i broke sumthan...NEED HELP!!! (brian22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian22 &raquo;</TD></TR><TR><TD CLASS="quote">do a leak down test and it will show it there if any valves are bent and where and yeah your lucky you didnt spin a bearing at 9000 </TD></TR></TABLE>
WTF?? the bottom end can handle 9000 rpm in stock form no problem. /educational moment. the head is another story
Old Nov 2, 2008 | 11:41 PM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">may possibly have destroyed the LMA's as well</TD></TR></TABLE>
Yep, or he tossed a clip or two!
Reading your sig - I'm curious...
Are you running the old skool LMAs with the tapered plungers or the new S2000 spring style LMAs???
https://honda-tech.com/zerothread/2312727
Old Nov 3, 2008 | 06:01 AM
wrenchez81's Avatar
Default Re: (BlackDeuceCoupe)
FTW!!! STRETCHED CONNECTING ROD!!!!!!! THE PISTON IS NOW CONTACTING THE CYLINDER HEAD!!!! if all he did was float a valve there wouldn't be a mechanical noise just a misfire at idle that would probably clear up.. other possibility is that u broke a valve spring... BUT AGAIN IS THE ENGINE MISFIRING??? if so and all you have is the noise your bout to sling a rod in my opinion...
Old Nov 3, 2008 | 07:28 AM
TravisCadello's Avatar
take the valve cover off and start it and see whats making the noise. or just feel each rocker arm and see if one came lose because at 9300 Rpm thats a **** load of vibrations and could caused a rocker arm to losen up a little and that will make the exhaust sound a little funny. kinda like its bogged down and has bad fuel but still run good. Why 9300 Rpms though? Why Not 10,300 that woulda been cool but really no point. if you knew you were going to go to 9300 you shoulda made a video so we can hear what a B16A1 sounds like right before it comes apart! Good Luck Man !
Old Nov 3, 2008 | 07:39 AM
slo_hatch's Avatar
Default Re: (sintype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sintype &raquo;</TD></TR><TR><TD CLASS="quote">
i agree. why rev to 9300? hahaha.</TD></TR></TABLE>
a guy locally missed a gear and revved to 13k....needless to say he [freak]ed up a piston bad. lol he showed me the piston and it looked like a ring around the outside of the piston and then shredded metal in the middle and the whole was practically the entire size of the piston. LOL
op: make sure you do a comp test and post up your results. if you have one cylinder that is alot lower than the rest then you have messed something up. i have heard a leakdown test is better for telling if you have a bent valve so also try that one. i would bet you will have to replace your valvesprings and retainers at least. good luck.
Old Nov 3, 2008 | 08:14 AM
DCSportEJ1Civic's Avatar
Bent valve
Broken valve
Broken valve spring
Holy pistons
you most likely trashed your valve train
Old Nov 3, 2008 | 08:30 AM
knoxcivic's Avatar
Default Re: (slo_hatch)
COMPRESSION TEST!!!!!!!!!!!!!!!!!!! why touch anything when the test will be a tell all?
Old Nov 3, 2008 | 08:43 AM
Default Re: (knoxcivic)
i just did a compression test on my single slammer and its was (#1-150) (#2-150) (#3-100) (#4-155) does 100 sound really low or bad?
Old Nov 3, 2008 | 08:46 AM
turbojdmhatch's Avatar
Default Re: (TravisCadello)
yea 100 is way to low
