Driver side axle help again!
Old Nov 2, 2008 | 06:26 AM
...rohit's Avatar
Default Driver side axle help again!
Hey everyone, I wanted to make sure this gap is normal? keep in mind its an auto teg ls if that makes a difference. I pushed as hard as possible. Thanks for any help!
Old Nov 2, 2008 | 06:40 AM
slaminsam's Avatar
Default Re: Driver side axle help again! (...rohit)
You said the drivers side axle right? Does the intermediate shaft bolt up correctly? Either way that doesn't look right to me.
Old Nov 2, 2008 | 06:53 AM
Status R's Avatar
Default Re: Driver side axle help again! (slaminsam)
doesnt look correct. ive only owned manual hondas but that gap def looks like it needs to be closed, try taking it out and putting it back in maybe the grooves arent lining up right and preventing it from going in all the way
Old Nov 2, 2008 | 09:36 AM
hollums2k's Avatar
thats an aftermarket parts house axle. i just went through the same thing - i went to napa, advance, orileys and all of them did that. its not going to go in any further
Old Nov 2, 2008 | 09:41 AM
projectTeG's Avatar
that loos normal to me, thats the female axle correct?
Old Nov 2, 2008 | 11:18 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yeah I think that is fine. As long as the female sleeve on the end of the inner joint cup is all the way up against the side of the half shaft bearing, it should be good.
OldSchoolFool
Feb 15, 2023 11:22 AM
92sully
Transmission & Drivetrain
12
Sep 15, 2010 01:09 PM
rhdekhatchie
Mar 16, 2008 10:17 PM
SoOHiGH
18
Jul 6, 2005 07:48 PM
ill phil
May 15, 2003 06:27 PM
