Question for the wheel guru
Old Nov 1, 2008 | 10:10 PM
ice-burg-slimm's Avatar
Default Question for the wheel guru
I have a 94 gsr and i simply want to know if i would have any issues using a 255/50/16 tire combo. Would the side wall of the tire be a problem.
Old Nov 1, 2008 | 11:42 PM
ruffrhyder's Avatar
Default Re: Question for the wheel guru (ice-burg-slimm)
How wide is the wheel or rim you plan on using?
Old Nov 2, 2008 | 06:42 AM
toyomatt84's Avatar
Sanji
255? You would need to get fender flares or something to cover that wide of a tire. Not to mention that the size (255/50/16) is WAY too large for the car.
Old Nov 2, 2008 | 06:53 AM
Default Re: (toyomatt84)
the reason why i'm doing that is because on a 16x7 rim, a 255/50 tireequal out to a 26" tall wheel tire combo.But since you guys are saying that a 255 will be too wide,i will just go with the 225/60/16,which equal out to the same.
Old Nov 2, 2008 | 07:02 AM
toyomatt84's Avatar
Sanji
Default Re: (ice-burg-slimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ice-burg-slimm &raquo;</TD></TR><TR><TD CLASS="quote">the reason why i'm doing that is because on a 16x7 rim, a 255/50 tireequal out to a 26" tall wheel tire combo.But since you guys are saying that a 255 will be too wide,i will just go with the 225/60/16,which equal out to the same.</TD></TR></TABLE>
Why do you want a 26" tall tire? You do know that it's horribly oversized for the car, unless it's strictly for track use. Plus, a 255 is rather wide for a 7" wide wheel.
Old Nov 2, 2008 | 07:27 AM
it's for track use.I'm setting the car up for the TX mile, so use a 26" tall tire combo would change my gearing to where i want it.But now base on your opinions i will be better off utalizing 235/60/15 wheel combo.That way when i'm done i can take those 15" wheels off and slap my 205/45/16 wheels on.
ITR3189
Nov 9, 2007 12:34 PM
boostjunkieee
Jan 14, 2007 11:23 AM
Touch
Jul 2, 2006 02:34 PM
SJR
Dec 3, 2004 08:25 AM
Flux
Mar 5, 2002 07:19 PM
