lake in the trunk!
Old Nov 1, 2008 | 09:57 PM
SkaiWu's Avatar
Default lake in the trunk!
car: is a DC
yes the infamous lakes...
ok so i have a giant LAKE in the trunk area where the spare tire is
and yep i don't remember if i plugged the moon roof tube... but i doubt that could cause a lake...
anyone else have a LAKE in the trunk? literally like a giant puddle down there w/ like some small swimming bugs and dead crap wow
today it rained so...
at the same time right now im reading 50 threads on trunkl eaks
rust rust
the next morning
Modified by SkaiWu at 12:16 AM 11/2/2008
Modified by SkaiWu at 11:05 AM 11/2/2008
Old Nov 1, 2008 | 10:19 PM
rhino87's Avatar
Default Re: lake in the trunk! (SkaiWu)
sit in your trunk and have someone hose the car. If you still cant figure it out then drill a drain hole
Old Nov 1, 2008 | 10:23 PM
Jimmy's Avatar
Global Moderator
Could be your taillight gaskets, taillights, sunroof drain tubes (if appliciable) antenna gasket..,etc.
search the terms ''water leak'' in recent and archived content and you will find that all of us integra owners have had this problem...
Old Nov 1, 2008 | 10:27 PM
Brice.Hayden's Avatar
Default Re: (Jimmy)
is it a DA or DC?
Old Nov 1, 2008 | 11:00 PM
1200 Hobos's Avatar
Default Re: (Brice.Hayden)
I want to say DC from the information in his sig. ?
Old Nov 1, 2008 | 11:09 PM
redGSRguy's Avatar
I had the problem too, turns out it was my tail lights! Good luck finding the problem. I have a driver side jdm tail light for sale if you are interested =D.
Old Nov 1, 2008 | 11:13 PM
majinsoftware's Avatar
DAs leak around the hatch seal quite often, Just drill a hole in it for the water to drain thats the best thing you can do other then permanently sealing the hatch. Dont know about DCs they might of fixed that problem in later models.
Old Nov 1, 2008 | 11:17 PM
SkaiWu's Avatar
i have jdm tail lights
anyways i'll check the drain tubes tomorrow, i should fasten them down w/ tape or zipties because according to the t-i article they can slip off
i'll be spraying water at the car after fixing the drain tubes to locate any other leaks
where would i drill a drain plug? would i not have a rusted hole if water keeps running out of it
Old Nov 1, 2008 | 11:58 PM
Dill it at the lowest point of the pooling, And paint over it so theres no exposed metal to rust.
Old Nov 2, 2008 | 06:54 AM
thabao's Avatar
http://www.team-integra.net/se...=1021
Old Nov 2, 2008 | 08:17 AM
tempname's Avatar
Default Re: lake in the trunk! (thabao)
Taillight gaskets.
Old Nov 2, 2008 | 10:05 AM
SkaiWu's Avatar
yep im checking today, after i check the moon roof tubes i'm gonna have someone sit in the trunk and spray the car down
Old Nov 2, 2008 | 10:37 AM
azzurribaggio's Avatar
Bro replace your tail-light seals. I had the same problem in the same area and after replacing the seals it never leaked again. The seals become so smashed over the years that they just don't seal anymore. When I got new ones I was pretty shocked to see the difference in thickness between new ones and the ones I replaced.
Old Nov 2, 2008 | 11:05 AM
SkaiWu's Avatar
how much are new gaskets?
if it is the tail lights i plan to do silicone like this guy https://honda-tech.com/zerothread?id=1948707
Old Nov 2, 2008 | 11:08 AM
Jimmy's Avatar
Global Moderator
Default Re: (SkaiWu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkaiWu &raquo;</TD></TR><TR><TD CLASS="quote">how much are new gaskets?
if it is the tail lights i plan to do silicone like this guy https://honda-tech.com/zerothread?id=1948707</TD></TR></TABLE>
http://www.acuraoemparts.com/d...ch=no
Old Nov 2, 2008 | 11:12 AM
TenaciousB18c1's Avatar
Default Re: (Jimmy)
Check the antenna hole too
Old Nov 2, 2008 | 11:20 AM
SkaiWu's Avatar
hopefully nothing comes out the antenna hole because i have it completely sealed off w/ a rubber grommet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.acuraoemparts.com/d...ch=no</TD></TR></TABLE>
oO! am i better off using silicone to seal along it?
no money
Old Nov 2, 2008 | 12:17 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkaiWu &raquo;</TD></TR><TR><TD CLASS="quote">hopefully nothing comes out the antenna hole because i have it completely sealed off w/ a rubber grommet
no money</TD></TR></TABLE>
Did you plug the antenna drain tube after removing the antenna? If not, the moon roof draining can leak from the tube into the trunk. Regarding locating a leak, I tape paper towels above the pool zone at suspected leak points. If a towel is wet, you've found a leak.
Old Nov 2, 2008 | 01:39 PM
vietnamezerice's Avatar
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkaiWu &raquo;</TD></TR><TR><TD CLASS="quote">yep im checking today, after i check the moon roof tubes i'm gonna have someone sit in the trunk and spray the car down
take off the rear plastic too when you do this, that way you can have a better view
Old Nov 2, 2008 | 07:43 PM
SkaiWu's Avatar
^ yea i did that to check today
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
Did you plug the antenna drain tube after removing the antenna? If not, the moon roof draining can leak from the tube into the trunk. Regarding locating a leak, I tape paper towels above the pool zone at suspected leak points. If a towel is wet, you've found a leak.</TD></TR></TABLE>
yea i plugged the antenna hole, we poured water the moon roof&gt;rear and have only come up with the left taillight gasket so hopefully... that left taillight gasket is THE ONLY leak since we didn't seem to find anything else
are those just foam pieces? i can buy a sheet of foam from a material place and just cut it out and would it work?
right now i'm bout to tape up the whole thing as a temporary fix, anyone think this will work?
and its gonna rain tomorrow too
Old Nov 2, 2008 | 08:05 PM
redGSRguy's Avatar
Buy my left JDM tail for $30 =P. I think user Patrickgsr94 or something had a whole write-up on making the gaskets back in the day.
Old Nov 2, 2008 | 08:28 PM
soontobeboost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkaiWu &raquo;</TD></TR><TR><TD CLASS="quote">car: is a DC
rust rust
the next morning
Modified by SkaiWu at 11:05 AM 11/2/2008</TD></TR></TABLE>
fudge the rain over the week!
Old Nov 2, 2008 | 09:38 PM
SkaiWu's Avatar
i have all reds already i just need a gasket, i also need money myself haha
i did a ghetto fix bout 1hr ago
used this guys silicone method except mine is white so its higher profile
Old Nov 2, 2008 | 10:22 PM
Circusraven's Avatar
Man, thought only DA's were prone to this. I just drilled a dang drain hole
Old Nov 2, 2008 | 10:58 PM
Ricextacy's Avatar
Default Re: (Circusraven)
see if there is water in your taillights bfore u replace the gaskets.
CWalsh
Other Make Vehicles
13
Oct 28, 2011 09:10 AM
HKSuperSi
Feb 9, 2008 10:15 AM
usdm420
Honda Motorcycles
32
Nov 11, 2004 11:23 AM
d16_civic
Jun 23, 2004 08:57 AM
Paranoid Android
40
Dec 2, 2002 07:29 PM
