Messed up Suspension/Alignment??
Old Nov 1, 2008 | 08:29 PM
Sidewayz_240's Avatar
Default Messed up Suspension/Alignment??
I have a 91 EF Si I just purchased with Integra disc brakes all around. And if I let go of the steering wheel, the car violently moves from side to side, and the tires screech when turning sometimes. The guy I bought it off of sais it has something to do with the DA knuckles??
Any help is greatly appreciated, because its really scary to drive in the rain lol.
Old Nov 1, 2008 | 09:03 PM
KillBot's Avatar
Sounds like you got screwed...unless you got it for dirt cheap...
LOTS of things to look for...
Out of balance wheel
Bent wheel
Loose hub/spindle bolt
Bad steering rack/joint
Bent frame
Bent suspention component
And more I am sure I am forgeting...
I have never heard of a DA knuckle doing anything like this...maybe a LITTLE wobble due to HORRIBLE alignment issues after the swap.
See anything obvious under the car or does it have any bad marks on the carfax/title?
Old Nov 2, 2008 | 04:22 AM
ej8's Avatar
ej8
Default Re: (KillBot)
best think to do is take it in for an alignment/ck suspension and a proper alignment tech will test drive, inspect, align (ck if can be aligned to spec or if needs to goto frame shop / part replacement), and test drive again. Thats what I do anyhow
Don't mess around with suspension...i see some scary stuff at work that shouldnt be on the road lol
Old Nov 2, 2008 | 11:32 AM
Default Re: (ej8)
Clean title, frame is straight.
Old Nov 2, 2008 | 01:48 PM
Tyson's Avatar
Default Re: Messed up Suspension/Alignment?? (Sidewayz_240)
did you get an alignment yet????
Old Nov 2, 2008 | 05:35 PM
Default Re: Messed up Suspension/Alignment?? (Tyson)
No but today, when I was going like 65 I had to brake suddenly, and my passanger side tire locked up, and skidded horribly, with smoke. It almost feeled like the tire went sideways?
Old Nov 2, 2008 | 05:43 PM
Coltmorris's Avatar
In my opinion, if you're going on a tech forum asking questions like these, you should just take it to a shop man. They'll road test it either way, and make their own decision. Unless you're planning on doing the entire repair by yourself.....
Old Nov 2, 2008 | 05:56 PM
strawberry's Avatar
sounds like its toed out to much. you need to have it aligned.
Old Nov 2, 2008 | 07:16 PM
Default Re: (strawberry)
I wanna make sure its not the alignment before I take it to the shop, because it would be pointless having it aligned, than fixing something else suspension wise, only to have it aligned again. Dont you think?
Old Nov 2, 2008 | 07:36 PM
Tyson's Avatar
Default Re: (Sidewayz_240)
dude, you just swapped a completely new front end suspension.
of COURSE you have to get an alignment!
its not even a question what your problem is.
its pointless NOT to get an alignment and try to figure out if anything else is wrong.
Old Nov 3, 2008 | 09:09 AM
Default Re: (Tyson)
I didnt do it, the guy I bought the car from did it.
Old Nov 3, 2008 | 10:06 AM
ef yu's Avatar
go get the alligment. if your car is lowered, i hear some shops wont do it.GL
Old Nov 3, 2008 | 10:14 AM
akandok's Avatar
I guess if you have not read up on Integra knuckles in an EF... this is how your wheels are supposed to be |---|, this is how they are now \---/
As previously stated, alignment will fix this.
Old Nov 3, 2008 | 10:08 PM
Default Re: (akandok)
Thanks for all the help, Im going to get it aligned this weekend. And BTW I like your sig, Yes on 8!
jdmdood
10
Jun 10, 2011 08:10 AM
chikin pickle
Oct 20, 2009 07:16 AM
prelude_93vtec
Apr 21, 2008 07:49 PM
dynamo
Jun 25, 2002 01:30 PM
