Tire rubbing at right turns
its probly your camber, it happened opn my toyota, cause when the car turns the car shell rotates in lack of words, and your camber or toe could be off just a bit more than the left ... try get an allignment first , if you have you can grind it down just make sure there are no sharp edges... gotta love negtive camber, my toyota pickup rim rubbed on the upper suspension arm when i turned left due to negative camber(went through front tires every two months)
98savage
Suspension & Brakes
20
Oct 25, 2008 06:31 PM
EnjoyTheRideDC2
Mar 2, 2006 04:05 AM
