Need help with 95 LS wiring...doing auto to manual swap
Old Nov 1, 2008 | 12:47 PM
catznmikeyboy's Avatar
Default Need help with 95 LS wiring...doing auto to manual swap
OK, we need to figure out what to do with the reverse lights, cruise control, etc. If anyone knows where the post is on here to figure this out, please let me know. THanks!!!
Old Apr 6, 2009 | 02:56 PM
alkoholikwun's Avatar
Default Re: Need help with 95 LS wiring...doing auto to manual swap
i too need help with this part of the project.
*bump*
sorry for also stealing your thread
- not sure if i need to use the connectors located inside the red circles
- reverse lights work (connect straight from manual tranny to this harness, connected the pink and black together for cruise control
- inside the red box: car shows on dash that its in park, but will not start, is this connection correct (2 big black wires & little green w/ white wire)? car should start w/out clutch pedal pressed?
- can anyone check to see of this connector located inside the ignition cover is suppose to be free, or connect to something, i cannot figure this out
- location of connectors 1 & 2 on auto tranny, DO NOT NEED anymore correct?
- location of connectors 3 on auto tranny, DO NOT NEED anymore correct?
- location of connectors 4 on auto tranny, DO NOT NEED anymore correct?
- 5 is vehicle speed sensor, got that plugged in
- so i ended up with 4 connectors that i now no longer need correct, because they were only needed on the auto tranny.
- my starter will wine up when i turn the ignition on, but it wont start. when the starter was put in another car, it worked fine.
- i believe with the way my harness is wired right now (1st pic), i should be able to start the car w/out using the clutch. if anyone else has another way to wire the main harness, that would be great.
KiDDD...
Jun 26, 2012 10:00 PM
getnasty
29
Feb 23, 2005 07:09 AM
SivikHatch
Jan 29, 2004 05:14 PM
DEVIN22CBR
Jun 12, 2003 07:03 PM
slow hatch
Dec 17, 2002 11:08 PM
