tps issue??
Old Apr 4, 2009 | 06:31 PM
littlered06's Avatar
Default tps issue??
i have a 96 integra ls with a 96spec type r swap and i cant seem to get the vtec to engage. i think the tps sensor is bad would that cause it? it has the jdm computer in it and a hasport jumper harness to run to the solenoid. the solenoid is showing that its getting power is possible that it could be bad still even though its getting power? any ideas or answers will be much appreciated.
thanks
brian
Old Apr 4, 2009 | 06:51 PM
Default Re: tps issue??
the car seems like it runs really well but it doesnt feel like it crosses over. someone told me there were different soleniods and one you dont feel the crossover as much?? im lost. i have tried searching and looking around with no luck
Old Apr 5, 2009 | 05:22 PM
anyone???
Old Apr 5, 2009 | 05:59 PM
Double Agent's Avatar
First off try to write more clearly so as not to make things confusing. Capital letters are your friend. A little more detail would help as well.
The TPS should not affect VTEC. If your TPS was bad you would likely have a bouncing idle or drivability problems. You can check the resistance on it to be sure if you want, I don't know the specs but it should be easy to search.
As for the solenoid... I'm not sure if there is a difference but are you using the one that is for the Type R or the one off your stock engine?
Old Apr 5, 2009 | 08:11 PM
the solenoid is the stock jdm one. from what ive been reading if the Tps isnt putting out the correct voltage the vtec wont work....
Old Apr 6, 2009 | 12:53 AM
Hanmin's Avatar
the tps has to read 4.5 at wot and .45 or .5 at closed. is the harness just an extension? Solenoids are all the same, it's either on or off, the cam profile is what makes vtec crack louder, or softer. or vtec engagement points.
Tps does affect vtec, I'm pretty sure that if your not at wot or close to it, vtec won't engage. Yes if the tps isn't putting out the correct voltage or close to it, it will not work. Go get a voltmeter and calibrate that pos.
Old Apr 6, 2009 | 05:04 AM
the harness is a hasport jumper to get vtec wired to a non vtec car. the car is obd1 converted
thanks. i just bought a new TPS from acura so i'll look up how to calibrate it then go from there!
Old Apr 6, 2009 | 09:15 AM
HONDRETTI's Avatar
acura sold you an individual TPS ? or did you buy the whole throttle body? just wondering...
Old Apr 6, 2009 | 11:10 AM
just the TPS. my buddy works there he just called and said he got me a new one in the box
Old Apr 6, 2009 | 11:50 AM
wunfstgsr's Avatar
Loved
Community Favorite
damn they wouldnt sell me one if my life depended on it lol.. its your conection to your vtec solinoid i gaurantee you it! your vtec should pop like crazy bammm! your waisting time on the tps if it was bad like said before you would jump around like a animal lol..
Old Apr 6, 2009 | 11:57 AM
Top Speed's Avatar
That's really weird. I did not think they sold just the TPS. At least they didn't when I worked at Honda.
Old Apr 6, 2009 | 12:32 PM
the car was scanned and it came back with a TPS code saying low voltage.....there is one local guy on our cincy forums that said he had the same issue im having so i dont know. all of the wires and connections on the harness look tight and correct
Old Apr 6, 2009 | 12:47 PM
TonyRomo's Avatar
My car was throwing that same code at one point and we replaced the tps with an aftermarket one and it still had the same problems. It ended up being the entire throttle body. I replaced it with a used one off ebay and so far so good. I doubt this would have anything to do with your vtec tho.
Old Apr 6, 2009 | 04:19 PM
i just swapped throttle bodies just for ***** and giggles and vtec popped so i guess i need to put that new tps on that throttle body asap
Swap'DShuttle
Jun 6, 2012 12:08 PM
MadCivic1999R
Sep 15, 2008 05:59 PM
poppypizza
Apr 26, 2008 07:29 PM
b16a3delsol
May 21, 2007 12:16 PM
EG-SI(rII)
Oct 3, 2005 01:41 PM
