94 ex brake rear brake pins stuck
i got a 94ex and i went to change the brake pins on the back because one of the threads are striped out on one and it won't move and i can't get new pads to fit on the outside.
what would be the be the best way to get that pin out.
i was thinking an air chisel.
any suggestions,thanx
Try to save the boot on the pin, stretch it carefully to remove it.
Squirt penetrating fluid around where the pin goes into the caliper , lock on some vise grips and pull and turn.
penetrating fluid will cause rubber to swell up and eventually crumble.
pityocamptes
19
Mar 2, 2012 02:26 AM
JDMTEG98
Suspension & Brakes
Jul 10, 2009 09:20 PM
hermtm2
May 8, 2009 10:33 AM
Tb0y
Jun 24, 2006 07:04 AM
