Driverside window won't go up...
Old Nov 1, 2008 | 09:16 AM
velocity101's Avatar
Default Driverside window won't go up...
I have a two door integra se. There's no problems with my passenger side window but my driverside window switch will allow the driverside window to go down but not up. I can get the window up with the alarm so I know it's not the motor. I figured it was just the switch so I rewired it so that on the driverside window control switch panel the switch for the passenger window would then control the driverside window and the driverside window switch would then control the passenger side window but still nothing. I can now use the button that used to control the driver side to make the passenger side window to go up and down but now the switch that use to work for the passenger window which now controls the driver side will again only allow the window to go down and not up.... Any ideas?
Old Nov 1, 2008 | 10:45 AM
Default Re: Driverside window won't go up... (velocity101)
nevermind.. i just figured it out. i traced the alarm wiring and there was a loose wire on the switch side. now i just have to redo the wiring back to its original switch.
oderfla90
Mar 15, 2017 08:55 PM
XLR8_HFX
Feb 9, 2008 05:07 PM
92ehatch
Mar 3, 2006 02:49 AM
