Fuel Pump
Old Oct 31, 2008 | 11:40 PM
byjl's Avatar
Default Fuel Pump....plzzz help!
I'd tried to start my 95 civic ex but not getting fuel. I'd read in the book that you are supposed to hear some kind of a swirling noise, and i did not hear it.
Does that mean the fuel pump is deffective?? all fuse and relays seems to be in the green.
Any help will be good and appreciated.
Old Nov 1, 2008 | 02:20 AM
Hanmin's Avatar
make sure its quiet, turn the key two clicks, and then it should come on, if its dead silent, then your fuel pump is not priming sir.
Old Nov 1, 2008 | 03:47 AM
turbo97coupe's Avatar
Default Re: (Hanmin)
its not really a swirling noise. when u turn the key to accessory u will hear a click from your main realy and you will instantly hear a humming noise coming from underneath the lower half of your rear seat . but like the person above said u have to be dead silent . if its not priming make sure your check your main relay its down by the kickpanel down by your hood release . hope i helped
Old Nov 2, 2008 | 09:37 PM
byjl's Avatar
Default Re: (turbo97coupe)
MY FUEL PUMP IS WORKING FINE BECAUSE I USED THE TESTER TO TEST IT.
AND MY RELAY SEEMS FINE.
the real problem is that when i try to start my car, it cranks but the engine wont start, yet it keeps cranking after the ignition is turned off,...wierd huh!
could it be my cut off relays???? cuz im about to blow this car into kingdom kum,
any1 who knows the answer to my problem will probably be worshiped 4ever.
Old Nov 2, 2008 | 09:44 PM
Default Re: (byjl)
so your saying with the key back to the off position the car continues to try to start ? thats a wierd one ive never came across that problem have u try'd the tech forum ?? maybe they can give u more insight to what could be cause this ? goodluck man dont give up on it
Old Nov 2, 2008 | 09:47 PM
byjl's Avatar
hyea i no its weird. could it be my floorboard harness????
Old Nov 2, 2008 | 10:05 PM
Default Re: (byjl)
its def. a electrical problem i would search the tech section and see if u can find out if theres a sensor or relay that controls the cranking or try changing your ignition those are just guess's but like i previously said repost in the tech section alot of very smart people lurk in there or trace the wires from your ignition and see if they lead to some sort of relay or sensor yet again another guess
Old Nov 2, 2008 | 10:13 PM
did some searching for u and found one car with the same problems these were the replys people gave
First thing is try unpluging the smaller 'signal' wire to the solenoid, if it still happens, smack the crap out of the starter, if it still spins the starter; I'd suspect a bad starter
sounds like the starter silinoid is stuck.
hope anything ive suggested helps man
Old Nov 2, 2008 | 10:20 PM
byjl's Avatar
hyea, i'll try doing that. but its a new starter so i think it could be the main harness,
but im still not sure.
thnx
Old Nov 2, 2008 | 10:22 PM
Default Re: (byjl)
no problem man the thread i found the car was doing the exact same thing your car is doing and the two options i posted in my last reply fixed the other guys car
Old Nov 2, 2008 | 10:26 PM
byjl's Avatar
haha, really, guess i gotta try it then
Old Nov 2, 2008 | 10:40 PM
Default Re: (byjl)
yea i definatly would goodluck man
slimsam1
11
Dec 28, 2008 01:30 AM
Jooleeus
13
Jul 20, 2008 08:46 AM
efking1985
Feb 16, 2007 07:39 AM
rleonekc
Feb 18, 2006 09:08 PM
