safe redline
Old Jul 30, 2002 | 05:23 AM
96_GSR's Avatar
Default safe redline
I have a Skunk2 chip on the way, and I'm wondering how high I can take my redline with stock internals, without doing any damage..I do have upgraded Skunk2 Stage 2 cams, gears, springs, and retainers..
thanks
Old Jul 30, 2002 | 06:44 AM
96_GSR's Avatar
Default Re: safe redline (96_GSR)
someone has to know!!!
Old Jul 30, 2002 | 07:29 AM
builthatch's Avatar
MiG-21 superfan
throw it on the dyno to see where the power peaks- but, I know of dudes takin stock bottom end daily driven b18c1's to 9k rpm. the head stuff ( i see your takin' care of that area) and tuning is what needs to be addressed, especially at those engine speeds, but the bottom end is solid- the stock rods are lightweight, the pistons are cast and light, and its balanced inherently
[Modified by builthatch, 11:29 AM 7/30/2002]
Old Jul 30, 2002 | 09:59 AM
gaskleppie's Avatar
Default Re: safe redline (builthatch)
Don't go higher then 9200rpm.
A friend of mine cracked his retainers at 9500rpm max. He dumped a valve, end of engine........
Old Jul 30, 2002 | 10:32 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
with STOCK internals?? stock cams, valvetrain, everything?
stay at 8100
Old Jul 30, 2002 | 10:49 AM
Default Re: safe redline (gaskleppie)
gee i wonder why
Old Jul 30, 2002 | 12:43 PM
Angry Joe's Avatar
Default Re: safe redline (dLo GSR)
stay at 8100
Read the original post. The cams and valvetrain are not stock
Old Jul 30, 2002 | 02:19 PM
SoulSurfer's Avatar
Default Re: safe redline (Angry Joe)
Dont the manufacturer papers give an RPM range?
Old Jul 30, 2002 | 06:54 PM
96_GSR's Avatar
Default Re: safe redline (9Grandr)
It doesn't slip at all, and only happens sometimes. I was going 25 mph and put in 5th, and it still acclerated with comprable to the tach..I'm wondering what else it could be.
Old Jul 31, 2002 | 09:53 AM
Kataku2K3's Avatar
I wouldn't take it up way high. If you are running a stock head that will probably be the first thing to fail from over reving. Just don't float ur valves. I would say 8400 or so......... but yea slap it on the dyno and see what you can make power too. If you can make power up there then upgrade what you need to to do it.
Old Jul 31, 2002 | 11:35 AM
Kamin's Avatar
stay at 8100
OWNED by not reading the origional post!
take it to a dyno and see where you stop making power.
asilaydying1984
14
Apr 2, 2005 05:55 PM
decible01
Jan 23, 2005 08:25 PM
Chris_Bye
Jul 3, 2004 05:23 PM
1hotintegra
Jun 21, 2003 08:01 PM
Unsung
May 28, 2002 08:08 AM
