instaling an amp noob question
Old Oct 31, 2008 | 09:19 AM
x4and3r1991's Avatar
Default instaling an amp noob question
can u instal an amp to a cd player if it doesnt have an RCA outlet on the deck? and if so how ?
Old Oct 31, 2008 | 10:38 AM
It Wasn't Me's Avatar
Default Re: instaling an amp noob question (x4and3r1991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4and3r1991 &raquo;</TD></TR><TR><TD CLASS="quote">can u instal an amp to a cd player if it doesnt have an RCA outlet on the deck? and if so how ?</TD></TR></TABLE>
Yes. Buy an amp the has high-level (aka speaker-level) inputs.
Instead of connecting RCA's to the amp, you connect your speaker wires to it.
(many amps have both types of inputs)
Old Oct 31, 2008 | 03:31 PM
doggworld1233's Avatar
or get a hi/low converter like the PAC SNI 35
Old Nov 5, 2008 | 11:17 AM
twentyhurtz's Avatar
Default Re: (doggworld1233)
just go to an audio shop and tell them your problem, i think we used to call them rf modulators, but i can't remember. Scosche makes them, rockford fosgate, most of your "wiring" companies do, there like 15-20 bux depending on where you go, i even think walmart has them, its just a little box, two rca plugs on one end and usually 5-6 wires on the other end, 4 are to piggyback onto speaker wires and the other two, usually brown, are shields/grounds.
Old Nov 5, 2008 | 05:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: (twentyhurtz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentyhurtz &raquo;</TD></TR><TR><TD CLASS="quote"> i think we used to call them rf modulators, but i can't remember.</TD></TR></TABLE> NO, you can't remember, an RF Mod is a different animal altogether, you would have called them LOCs.
x4and3r1991 Yes you can, as mentioned you need an amp with speaker level inputs or you can get a LOC, it will convert your "high level" speaker outputs to a "low level" RCA output.
Most amps have speaker level inputs. 94
Old Nov 5, 2008 | 06:23 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (fcm)
and, to complicate matters more, certain OEM radios have signals that roll off the bass response to protect the speakers. an example of this is the mazda 3 without the Bose system.
so, to add an amp to that type of situation, you would get something like an MTX re-q to restore the bass in the signal, and give you the pre amp outputs that you need. a typical line out converter won't work well for this type of application.
lsnonvtec
Audio / Security / Video
Aug 5, 2007 05:30 AM
92-LS-Civic
May 1, 2006 11:19 PM
dcviperboy
Nov 17, 2003 12:16 PM
jokerstud
Jan 13, 2003 10:34 AM
