Suspension & Brakes Theory, alignment, spring rates....
Is this Ground Control sleeve load bearing?
Old Oct 31, 2008 | 12:18 AM
beanbag's Avatar
Default Is this Ground Control sleeve load bearing?
The edge looks kind of thin and rounded. I have a circlip adapter ring on my shock that has a flat surface for this to rest on. Will this be ok?
Old Oct 31, 2008 | 06:45 AM
gabebauman's Avatar
Default Re: Is this Ground Control sleeve load bearing? (beanbag)
That doesn't look like a Koni specific Ground Control sleeve. Mine have a small black lip on them just inside the sleeve and that part rests on the Koni's height adjustable circlip.
Old Oct 31, 2008 | 02:23 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beanbag &raquo;</TD></TR><TR><TD CLASS="quote">The edge looks kind of thin and rounded. I have a circlip adapter ring on my shock that has a flat surface for this to rest on. Will this be ok?</TD></TR></TABLE>
i hope that "adapter ring" has a proper design to enclose and capture the koni snap ring. or you will have disastrous results.
and yes, the sleeve is load bearing but works fine when used properly with a stock shock.
Old Nov 2, 2008 | 05:43 AM
JOE BD-0's Avatar
Default Re: Is this Ground Control sleeve load bearing? (Tyson)
yeah buddy, I had a bad "sleeve" sent from Koni once....It did not have the little lip machined into the bottom end of it and the conical shape that was there instead actually pushed the circlip down and out of the groove during a race.....It was the worst handling car I ever had....Talledega clockwise at Buttonwillow with NO front right spring was crazy crazy bouncy, a REAL handful.....
401B18TEG
Suspension & Brakes
Dec 19, 2007 12:13 PM
Ultraspeed DC2
Suspension & Brakes
Aug 10, 2006 11:38 AM
t0ekn3e
Jul 30, 2004 12:37 AM
36Chambers
Jul 5, 2004 06:58 AM
Mr HYDE
16
Dec 18, 2003 05:39 PM
