Suspension & Brakes Theory, alignment, spring rates....
type r rear sway kit from jhp?
Old Oct 30, 2008 | 09:10 PM
91bluehatch's Avatar
Default type r rear sway kit from jhp?
k, i just received the type r rear sway bar kit from jhp today. It came with the type r end links, bushings, and mounting brackets. i know I'm missing some misc. hardware(nuts/bolts) could anyone tell me exactly what I am missing?
Modified by 91bluehatch at 10:24 PM 10/30/2008
Old Oct 31, 2008 | 12:08 AM
Default Re: type r rear sway kit from jhp? (91bluehatch)
So I just read that I need to get Si end links to install the bar on my coupe. Can I still use the bushings and bushing collars that came with the bar with the Si end links or do I have to get the asr metal bushings?
Modified by 91bluehatch at 1:29 AM 10/31/2008
Old Oct 31, 2008 | 01:13 AM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91bluehatch &raquo;</TD></TR><TR><TD CLASS="quote">So I just read that I need to get Si end links to install the bar on my coupe. Can I still use the bushings and bushing collars that came with the bar with the Si end links or do I have to get the asr metal bushings?
Modified by 91bluehatch at 1:29 AM 10/31/2008</TD></TR></TABLE>
the only thing you'll need are the si endlinks and bolts/nuts, the should fit. will you but using a the ASR subframe brace? If not, its required so make sure you invest in one.
Old Oct 31, 2008 | 02:50 PM
Default Re: type r rear sway kit from jhp? (bmoua)
Yeah I already have the asr brace. I just ordered the si endlinks with nuts.
Old Nov 1, 2008 | 11:38 AM
k I just got the si endlinks, can I use them with the itr rear bars bushings without the bushing shims?
b20vteg757
Suspension & Brakes
12
Nov 24, 2013 05:49 AM
chinkyx90
Feb 13, 2009 12:32 PM
Mikes2000civicsi
Suspension & Brakes
Mar 27, 2008 10:17 PM
luvtositdumpt
Suspension & Brakes
Jan 30, 2008 08:10 AM
BigZ88
11
Jun 2, 2003 05:35 AM
