Rear sway bar for 00 sedan
i know that the civic 00 sedan does not come with end links, and suppsoedly you need to buy an adapter to put on a rear sway bar(i think).
With that said, can anyone suggest a good sway bar set+brace, and what i need to mount it on? thanks
Re: Rear sway bar for 00 sedan
buy complete asr kit
comes with everything, mounts new bolts, new sway bar,new end link, new bushing and brackets... if you piece this kit together but not not get the end links and use the stock lower control arms you can use SI end links.
so you know that your chassis has issue with subfram tear out even with stock si and gsr sway bars ..i sugest some prevention of this with the asr kit of something similar. i have never used anything but asr honestly
You won't have tearout with a stock integra bar or the Si(same diameter anyway). An ASR brace with a 13mm bar is a tad bit overkill anyway if you know what I mean.
Op, the ASR kit is very nice with their 24mm or the 22mm Type R bar. If you order the kit it comes with links from an Si. Brackets, longer bolts, and all the bushings you need. I've had mine on my car for two and a half years with no problems at all.
Comptech and Suspension Techniques also make good stuff but you will need a brace from Beaks or ASR.
Good luck!
Good luck!
Thanks!
I was also looking at some front and rear upper strut bars. Do i need to have a strut bar to have a strut brace?(sorry for the newb questions).
Also, anyone know of good strut bars and where to buy them thanks!
