CRX Problem Need HELP ASAP!!!
Old Oct 30, 2008 | 06:31 PM
almostjdmeg's Avatar
Default CRX Problem Need HELP ASAP!!!
I have a 1991 Crx si with a b18a1. When im sitting there idling it surges from 500 to 1500. I already cleaned out my iacv and was wondering if it could be something to do with my alternator, because when it surges my lights go dimmer and then brighter. Or could vaccum leak cause this surge and my lights to be dimmer and brighter? THanks
Old Oct 30, 2008 | 06:44 PM
KRock459's Avatar
Default Re: CRX Problem Need HELP ASAP!!! (almostjdmeg)
"Or could vaccum leak cause this surge and my lights to be dimmer and brighter?"
I think you nailed it, my guess is a vacuum leak. The alt. will put out more voltage at 1500 than 500, 500 RPM is very low Rs for a alternator.
Kirk R
Old Oct 30, 2008 | 07:39 PM
ivanson's Avatar
yea i think if you clean it, some of the time it wont work with
just a cleaning, could be bad.
Old Oct 31, 2008 | 07:33 PM
Default Re: CRX Problem Need HELP ASAP!!! (ivanson)
What? i dont understand what the above post means.
Old Oct 31, 2008 | 11:12 PM
ludesrv's Avatar
Clean it with brake clean. Soak it. try to clean the tubing as good as possible (free of crud). If it doesn't fix it just replace it. Go to your local dealership or scrap yard (you can find a good one from an accident car). Almost any honda (or acura) will do.
Bring your old one and compare bolt patterns. I know honda has 2 different styles, but I don't know the specific engines to which you can find a good part.
CR-XSI91
Sep 25, 2012 10:02 PM
misael-crx1986
Mar 4, 2009 12:55 PM
herlihy433@yahoo.com
Jun 15, 2008 07:04 AM
dac123
Feb 18, 2008 07:02 AM
flordo09
19
Apr 18, 2004 07:22 PM
