ABS wiring removal
I have searched high and low, all I seem to find are threads debating the importance and purpose of ABS. My ABS modulator is toast and they are way expensive. I have already removed my ABS control unit and the wire harness that runs along side of the passenger seat and plugs into a large orange connector near the ECU. Basically what I have left is the wiring from that plug on through the firewall to to ABS fuse box and modulator. Has anyone had any experience doing this? That particular wiring seems to be going into the main wire harness, will have to cut the wire loom open and remove the ABS wires? Thanks!
I wish someone could answer that question... I just remove everything relate to abs under the hood, sensor too... Now I have all these orange plug in the way under the hood... Can I just cut it? I don't want to remove the whole main harnesss for now.
Can I cut that bunch of abs wire?
nonpoint986
15
Apr 5, 2013 03:32 PM
