The best bolt ons??
lemme specify here. haha out of a header, intake manifold, CAI/ ram intake, uhh i guess throttle body spacer, injectors. etc. well they all say some
"hp gain and huge acceleration boost" haha u know but what REALLY are the good mods?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigsnorlax »</TD></TR><TR><TD CLASS="quote">What kind of bolt on modifications or combination would give me the most bang for my buck on my type of engine?</TD></TR></TABLE>
knowing that you have a LX model, from my personal experience and preference, i think an intake (short ram should do it) and a 4-2-1 header will make you feel very happy about your car's performance.... even you keep your stock muffler in place.
Not only this is somewhat "cheap", it's easy to be installed as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">My opinions
- suspension
- wheels and tires
- i/h/e
- cosmetic stuff if you want
- performance stuff (cams, lsd, etc)</TD></TR></TABLE>
X2
good clutch n flywheel
short shifter
93 or better
underdrive pulleys
50 shot
- suspension
- wheels and tires
- i/h/e
X2
short shifter
93 or better
underdrive pulleys
50 shot
turbos bolt on... lol
unless you plan on building up the motor bolt on's arent going to give you a whole lot of hps... they help out when you've built up your motor... but you're not gonna be runnin 14s with jus bolt ons.. I'd say build up you're motor for turbo or get an h22
or like muffin said... do suspension... that helps more than you would think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scabbs »</TD></TR><TR><TD CLASS="quote">turbos bolt on... lol
I agree. Bolt-ons give your ego a bigger boost than your car. They're nice initially and sound awesome but the real HP gains come from more serious mods like turbos, super charger's, or an engine swap.
P.S. bolt-ons also make your hard-on's harder. I think it correlates with the whole ego thing
</TD></TR></TABLE>I agree. Bolt-ons give your ego a bigger boost than your car. They're nice initially and sound awesome but the real HP gains come from more serious mods like turbos, super charger's, or an engine swap.
Really depends on how much money you have to spend also... But first things I would purchase for performance and best bang for our buck would be
Headers/ Possibly full exhaust without tip
Cold Air Intake
Lightened Pulleys
Cams
Fuel Injectors
But if you have a few bucks to spend then a turbo and boost controller would be the best!! With some upgrades on your engine so it doesn't blow.
Cold Air Intake
Lightened Pulleys
Cams
Fuel Injectors
thanks so much on the advice. Buuut if i do turbo my car...and i mean a low turbo so dont have to change out the internals like.. could i run 10 psi without having to change my internals? and is there a cheaper route to geting a turbo?? i dont exactly have 3000$$$ dollars layin around.. haha
a general rule of thumb is speed doesn't come cheap... just a thought! i am kind of wondering if it's even worth putting money into my stock motor. i think it would be smarter to take the money that i would spend on bolt on mods and put it towards a swap or whatever.
yeah ive been thinking that too... but in my opinion i think it would be cooler to see a built f22 then some h22 or something that EVERYONE always swaps for
Suspension and Wheels/Tires make a huge improvement over the stock slushbox. Invest in that first and then you can start doing other stuff.
Lighter wheels and better gripping tires coupled with some stiffer suspension components =
don't forget with your standard bolt ons to get a proper tune!
Tune is everything!
as far as boost, if this is your DD do not boost it!
even at 10 psi your gunna wanna bump it up, damagaing some components.
Why, well just because you can and thrive for more power.
I safely boosted my 320,000 mile stock F22(non V-TEC) with 9 lbs and it ran kick ****.
But again it is all in the tune, and running proper components.
I also have 3 cars and a truck so am available to break them if need be.
Cheap parts = more worries!
Tune is everything!
