94 Accord into 96 Accord Auto HELP
Old Oct 30, 2008 | 04:41 PM
SAVIOVEGA's Avatar
Default 94 Accord into 96 Accord Auto HELP
Ok, I hope someone can help. The car is a 96 Accord (obd2a) and the engine is Obd1.
Would I use the 94 engine harness or the the 96 engine harness ? And besides the obd2>obd1 jumper harness for the ECU, what needs to be done as far as the TCM goes?
Old Oct 30, 2008 | 05:16 PM
LA_HONDAS's Avatar
Default Re: 94 Accord into 96 Accord Auto HELP (SAVIOVEGA)
if your putting the motor in a 96 then you use the harness for the 96
same go's for any car
Old Oct 30, 2008 | 05:19 PM
SAVIOVEGA's Avatar
Default Re: 94 Accord into 96 Accord Auto HELP (LA_HONDAS)
yea, that's what I was thinking for the engine, but what about for the auto transmission? On the 94 accord, right above the ECU is the TCM. On the 96, it's not there.
Old Oct 30, 2008 | 05:42 PM
LA_HONDAS's Avatar
wait..... you want to convert it to an auto? if so good luck with it thats alot of wiring
and if its already auto just swap the motor and be done with it
Old Oct 31, 2008 | 09:07 AM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SAVIOVEGA &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I hope someone can help. The car is a 96 Accord (obd2a) and the engine is Obd1.
Would I use the 94 engine harness or the the 96 engine harness ? And besides the obd2&gt;obd1 jumper harness for the ECU, what needs to be done as far as the TCM goes? </TD></TR></TABLE>
Are the engines the same?
Or if you are converting an accord to a H22a OBd1 auto setup, then enjoy one of my automatic harnesses....
Auto to Auto wiring pain relief...
Zipl0cc
Jul 20, 2017 02:13 AM
1native
Jun 13, 2015 07:14 AM
baboonstyle
Jun 19, 2005 03:44 PM
