slipping clutch?
most likely needs a new clutch. try to adjust the cable but i doubt that is your problem
the clutch itself, can not be adjusted.
take a look at your bell housing and see if you have a leak. might be your main seal or the input shaft seal leaking on your clutch causing it to slip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc »</TD></TR><TR><TD CLASS="quote">most likely needs a new clutch. try to adjust the cable but i doubt that is your problem
take a look at your bell housing and see if you have a leak. might be your main seal or the input shaft seal leaking on your clutch causing it to slip</TD></TR></TABLE>
thats all correct. The only way your clutch cable could affect the situation is if it is preloading the pressure plate from being wound way too tight.
I agree that a new clutch is needed. For what it is worth, i run an ACT stage 1 clutch and i am really happy with it in my DD, and it holds like crazy for my lower power application.
danno33
12
Sep 30, 2012 08:46 PM
djsire
Sep 7, 2005 04:14 PM
I8ayellowcrayon
Aug 23, 2004 07:18 PM
