Installing trunk light.Need to know closest constant power source.
Old Oct 30, 2008 | 12:32 PM
fryman's Avatar
Default Installing trunk light.Whats the closest constant power source?
I'm installing a trunk light in my 93 dx sedan.As far as I know I run the green wire to the trunk trigger wire(negative trigger) and then run the white/red wire to a constant power source right?So my question is what is the nearest constant power source to the trunk?
Old Oct 30, 2008 | 12:36 PM
davefromPA's Avatar
Default Re: Installing trunk light.Whats the closest constant power source? (fryman)
fuel pump?? the brake lights also are always able to light up even when the car is off so maybe that would be even better
Old Oct 30, 2008 | 12:39 PM
fryman's Avatar
Default Re: Installing trunk light.Whats the closest constant power source? (davefromPA)
I tested the rear lights with a lest light and apparently all the rear lights are positive triggered so they don't have constant power .Any idea where the trunk lights on other models get their power from?
Old Oct 30, 2008 | 06:09 PM
fryman's Avatar
Its ok I figured it out.I just ran a wire across the ceiling to the interior light wire and ran a wire to the trunk trigger wire.
OneFire
Jun 2, 2011 09:07 PM
Lucman
Dec 9, 2008 01:42 PM
ScuderiaFerrari
24
Nov 8, 2004 07:41 PM
WHIT
Nov 19, 2002 11:13 AM
lostsurfer00
Oct 13, 2002 08:19 PM
