Q: will a B20 (CRV) head work on a LS block work? :searched:
Old Oct 30, 2008 | 11:01 AM
omiehomie's Avatar
Default Q: will a B20 (CRV) head work on a LS block work? :searched:
i have been looking through honda tech for a definitive answer with no luck.
Rundown:
i have a 95 LS and it has a b20 engine in it currently. the bottom end of the engine is toast due to the previous owner's neglect. i managed to get a hold of a running LS block for cheap.
i was wondering if i could still use the B20 head? or would i have to source out a LS head to get the car running again? any help is appreciated. thanks again
Old Oct 30, 2008 | 11:15 AM
LA_HONDAS's Avatar
Default Re: Q: will a B20 (CRV) head work on a LS block work? :searched: (omiehomie)
as long as its not a jdm b20(pr8) head it will work
all usdm ls and b20 heads will have pr4 on it on the exh side of the head
Old Oct 30, 2008 | 01:25 PM
omiehomie's Avatar
Default Re: Q: will a B20 (LA_HONDAS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LA_HONDAS &raquo;</TD></TR><TR><TD CLASS="quote">as long as its not a jdm b20(pr8) head it will work
all usdm ls and b20 heads will have pr4 on it on the exh side of the head</TD></TR></TABLE>
dude i cant thank you enough for the info
can anyone else confirm this?
Old Oct 31, 2008 | 10:57 PM
98lude-t's Avatar
Default Re: Q: will a B20 (omiehomie)
more like p75 but even thep8rhead will work as long as its not boosted. ive done both.
Old Nov 1, 2008 | 12:11 AM
omiehomie's Avatar
Default Re: Q: will a B20 (98lude-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98lude-t &raquo;</TD></TR><TR><TD CLASS="quote">more like p75 but even thep8rhead will work as long as its not boosted. ive done both.</TD></TR></TABLE>
nice what head gasket would you recommend i use the LS one or the CRV one? and is there any reason why it would not hold up for boost?
Old Nov 1, 2008 | 11:39 AM
iwanttokillgod's Avatar
this is not true i am currently running the p8r head and my ls b18a1 bottom end with no issues
Old Mar 15, 2012 | 06:47 AM
Digital Punk's Avatar
YES IT WILL. I have a 94 LS Integra, B18b1 bottom with a jdm B20 PR8 head. It bolts right up. This B20 head has a bigger cam lobe,(ONLY ON THE PR8 HEAD) that's it. All other head components are the same as the LS head, it's still a P75 casting. It will give you more low-end torque along with good response. :-)
Old Mar 15, 2012 | 08:17 AM
Vinnie909LSVTEC's Avatar
^ wow Bump from the dead! on your 1st post! way to go!
kaduku
15
Jul 3, 2009 07:54 AM
Damills
Mar 10, 2009 11:32 AM
E_F_9
10
Feb 12, 2006 07:32 PM
B20BHatch
Aug 12, 2004 08:40 PM
