wiring up o2 for a swap
Old Oct 30, 2008 | 09:23 AM
s1ngleslam's Avatar
Default wiring up o2 for a swap
okay i have a 94 cx hatch. did the d16z6 swap. since i had the b8engine with the one wire o2 do i need to wire up to the ecu? i have the z6 complete as well as the z6 harness but then again the harness just goes up to the shock tower. do i need to route more wires from the shock tower to the ecu? or am i good since i got the z6 engine harness??
Old Oct 30, 2008 | 10:47 AM
95vxtealhatch's Avatar
Default Re: wiring up o2 for a swap (s1ngleslam)
WHAT?
Old Oct 30, 2008 | 11:02 AM
davefromPA's Avatar
Default Re: wiring up o2 for a swap (95vxtealhatch)
did this same swap but i used a b7. you do not have to wire to the ecu. just plug it in the shock tower.
davefromPA's Avatar
Default Re: wiring up o2 for a swap (davefromPA)
only thing you need to wire in is vtec. everything else is wired in.
Old Oct 30, 2008 | 11:14 AM
s1ngleslam's Avatar
yea i went outside and checked the wires should b a6 wich is orange and black and d14 wich is white and i did have them so yea thanx bro.
turboef90
Dec 25, 2007 10:00 AM
MniMeHatch89
Feb 6, 2006 11:38 AM
Jmunk
Feb 6, 2005 08:28 AM
dogfood
Jun 5, 2004 12:03 AM
pnltnc
Apr 15, 2004 04:39 PM
