what type of transmission fluid is used for 1986 civic 1.3l 4spd manual?
Old Oct 30, 2008 | 07:16 AM
driftwood's Avatar
Default what type of transmission fluid is used for 1986 civic 1.3l 4spd manual?
anyone know what fluid is safe to use on these transmissions?
Modified by driftwood at 8:33 AM 10/30/2008
Old Oct 30, 2008 | 10:02 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
5w-30 should be more then fine.
Old Oct 30, 2008 | 11:10 AM
vtecb18c's Avatar
Default Re: (ComeOnKip)
being that its an 86, i wouldnt trust anything but Honda manual trans fluid or pennzoil syncromesh(gm is discontinued)...i wouldnt use motor oil....ive only used it in a jam..like i put a crack in my ys1 tranny and i had to make it home from dinner which was an hour away and all i had was a quart of oil.....use the right stuff so you wont run into problems later
Old Oct 30, 2008 | 03:17 PM
honda.lioness's Avatar
Default Re: what type of transmission fluid is used for 1986 civic 1.3l 4spd manual? (driftwood)
Contrary to what the original owner's manual says engine oil is no longer optimal for trannies, because engine oil chemistry has changed. Buy OEM manual tranny oil at the dealer.
The good news is that you can keep the OEM oil in longer, so it does pay for itself. See my writeup at http://honda.lioness.googlepag...fluid
Kaliona
38
Aug 3, 2009 05:53 PM
GSR_hatch936
36
Nov 12, 2007 08:53 PM
crxpwr1
14
Mar 17, 2007 12:02 PM
zx2gotboost
39
Jan 4, 2006 04:01 PM
jagged4698
Nov 22, 2004 12:58 PM
