unanswered swap question
Old Oct 30, 2008 | 04:13 AM
90Rexx's Avatar
Default unanswered swap question
so ive searched and found nothing on this subject.
swapping a bone stock usdm gsr (obd1) motor into a obd2a car....the easy way out is to use a obd2a vtec wire harness....now heres the question, regarding the gsrs butterflies on the Intake mani, is there any wiring involved? or are the butterflies only vacuum controlled?
Old Oct 30, 2008 | 04:49 AM
i drive a honda's Avatar
Default Re: unanswered swap question (90Rexx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90Rexx &raquo;</TD></TR><TR><TD CLASS="quote">so ive searched and found nothing on this subject.
swapping a bone stock usdm gsr (obd1) motor into a obd2a car....the easy way out is to use a obd2a vtec wire harness....now heres the question, regarding the gsrs butterflies on the Intake mani, is there any wiring involved? or are the butterflies only vacuum controlled?</TD></TR></TABLE>
ecu controlled.
leave the wriing alone to leave them open all the time
Old Oct 30, 2008 | 06:00 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: unanswered swap question (i drive a honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i drive a honda &raquo;</TD></TR><TR><TD CLASS="quote">
ecu controlled.
leave the wriing alone to leave them open all the time </TD></TR></TABLE>
Yeah I mean because Honda's engineers didn't know what they were doing when they engineered the butterflies to open up at 6000-6200rpm, and remain closed otherwise.
How long did you search, because there are a ton of topics about OBD1 engine into OBD2 car. I just posted a ton of info in one that's probably still on one of the first few pages in this 92-00 Civic forum.
1. You must use the Civic engine harness as it is a one piece design that goes all the way through the firewall and into the ECU itself. The Integras all had a two piece engine harness that stopped at the shock towers.
If you think the butteflies are you biggest concern then you might not realize there's a lot of extra parts swappin and wiring involved than just that.
The OBD1 GS-R engine will have different plugs on:
A. Distributor - swap for OBD2 96-01 Integra GS-R/ITR, 96-97 Del Sol VTEC, or 99-00 Civic Si
B. Injectors - retain stock Civic ones, rewire the plugs and use the OBD1 Integra ones, or find OBD2 B series injectors
C. Alternator - remove the case covering for the stock D alternator and the B18C alternator and swap out the voltage regulator where the engine harness plugs into it, or buy an OBD2 B alternator
D. OBD1 engine lacks a CKF sensor and if the car needs to be OBD2 to pass emissions you'll have to do a wiring trick to keep from throwing a check engine code:
Click Here and Floow OBD2S Instructions
E. IACV valve (Idle air control valve) is likely going to have a different plug than the OBD2 Civic
F. Knock sensor
The B18C1 uses one; the Civic isn't wired for one
If it does then Click Here and Find IACV Wiring Instructions
Also is this car an EX model, or a CX/DX/LX? If it's one of the non-EX models then you will also have a lot of fun when you realize that the oxygen sensor locations are in a completely different spot. This requires extending the wires for both sensors.
Basically this is a start for you. Click that link I provided for the IACV instructions and it will also give you detailed diagrams and pin-outs for different OBD generatons as they apply to swaps.
Old Oct 30, 2008 | 11:22 AM
90Rexx's Avatar
Default Re: unanswered swap question (B18C5-EH2)
lol...actually im aware of all this, and im using a 96-98 ex harness to bypass most of the wiring bullshit, my concern was said harness has no wiring for butterflies...
Old Oct 30, 2008 | 12:01 PM
dam_teg98's Avatar
i zip tied mine to stay open all the time to bypass all the wiring, works for me.
Fat Chick Magnet
Jan 1, 2007 03:46 PM
dohdoh420
Jan 22, 2006 01:59 PM
makoto
Jun 27, 2005 04:15 AM
ismkv8s
Honda S2000
May 2, 2005 10:31 PM
jmk2888
10
Jan 12, 2005 11:29 PM
