WTF?? trans gearing question?
Old Oct 29, 2008 | 10:54 PM
92egcivicls's Avatar
Default WTF?? trans gearing question?
ok so have a b18b1 swap in my gutted eg hatch,with what i thought it was a stock ls tranny. its has a sticker that reads s80 3150837 AND HAS A MARKING ASD?
and from what ive heard ls trannys are too long<tall geared>
but mine isnt wtf?
i have 185 60 14 tires,like i said the car is gutted but looking at these postings here:
http://hondaswap.com/reference...28672/
im shifting at 7800 rpms in my hatch into 3rd at 50 mph as seen in this video here
right click save as:
http://www.plastikhosting.net/...3.wmv
are the tires and weight throwing off the ratio that bad?>
according to that link above i should be able to get to 99mph in 3rd gear?NOT GOING TO HAPPEN!!!!! 80 to 82 mph MAX,PLEASE EXPLAIN!
Modified by 92egcivicls at 1:59 AM 10/30/2008
Old Oct 29, 2008 | 11:04 PM
Default Re: WTF?? trans gearing question? (92egcivicls)
come on someone help me,lol other then the sticker with the bar code how do i know what trans i got?
it cant be the factory ls trans! i have no way to get in touch with old owner?
Modified by 92egcivicls at 1:17 AM 10/30/2008
Old Oct 30, 2008 | 12:32 AM
gsr trans right? it would have to be!
Old Oct 30, 2008 | 03:52 AM
King V's Avatar
Check this out, maybe it might help>> http://www.ff-squad.com/tech/temp/Bgears.htm
Old Oct 30, 2008 | 05:46 AM
B18C5-EH2's Avatar
Former Moderator
Loved
The only way to truly know is to remove the tranny and split the case, then start counting teeth on the FD, gears, etc. and do the math.
A bootleg way would be to find someone else with an Integra LS or known LS tranny in his/her car and make sure you both have the same exact wheel/tire size, then do some side-by-side cruising in different gears and see if the rpm matches up.
Boostage
Nov 14, 2011 03:50 AM
repingjdm
11
Feb 15, 2011 07:11 PM
92egcivicls
Transmission & Drivetrain
Nov 1, 2008 01:31 PM
searching
May 9, 2005 08:15 PM
92HB_HB
Mar 25, 2003 09:27 PM
