I bought a GSR block and saw this?!?! Can i bring it back to life?
The guy i bought this from said its a spun bearing. I got it for a low ball price and thought i can re-build it. Where do i start?
Pics of the #2 rods
Pics of the #2 rods
wow man
yea its fixable but i suggest you get the block hot tanked
and the crank may be no good now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveo135 »</TD></TR><TR><TD CLASS="quote">and the crank may be no good now</TD></TR></TABLE>
Almost definitely, but depends on how long it was ran like that.
Hopefully you got the "bare" block for cheap
Hopefully i can tear it down this weekend and take more pictures. it came as a complete short block. The guy said he took it out after he heard the noise. i got it for $60 btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee_SydekicK »</TD></TR><TR><TD CLASS="quote">Hopefully i can tear it down this weekend and take more pictures. it came as a complete short block. The guy said he took it out after he heard the noise. i got it for $60 btw.</TD></TR></TABLE>
I wouldn't lose any sleep over it then, 60 is a steal even for a Bare block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm »</TD></TR><TR><TD CLASS="quote">
I wouldn't lose any sleep over it then, 60 is a steal even for a Bare block.</TD></TR></TABLE>
Word, If OP paid like 200-300 for the block then I would have said he got ripped off. But $60 for a block with matching mains, that's a deal in itself.
You could save yourself a lot of trouble and trade it or sell it for one that isn't screwed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow »</TD></TR><TR><TD CLASS="quote">You could save yourself a lot of trouble and trade it or sell it for one that isn't screwed up.</TD></TR></TABLE>
So trade a possibly fk'd crack, for a good one? How would you go about doing that?
Depending on how bad it is, the journal might only need slight resurfacing,
and if that doesn't work, just buy a new(used) crank, and put it together.
and if that doesn't work, just buy a new(used) crank, and put it together.</TD></TR></TABLE>
Offer a little bit of cash and tell 'em it spun a bearing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow »</TD></TR><TR><TD CLASS="quote">You could save yourself a lot of trouble and trade it or sell it for one that isn't screwed up.</TD></TR></TABLE>I'll trade you my broken set of rims for your good set of rims.how does that sound?
It sounds like something an idiot would say. Rims dont have parts. He got the thing for $60, so trade it plus cash for one that isn't screwed up and save yourself a lot of time and effort. Is that really so hard to understand?
What about buying an LS crank and rods with ARP rod bolts for cheap and enjoy your extra displacement.
Assuming he can do all the work himself then why not. I'm just trying to say that you don't want to go and spend more to repair the damn thing then what one in working order is worth.
u need new crank/ rods/ oil pump and an ocd cleaning. thats all
might need to touch up cylinder walls if they got scratched
I would say the best thing to do is purchase new internals(pistons, rod bearings) Usually when a engine is ran with no oil the rod bearings are first to go.. n this one looks pretty bad..so i say you also check the main bearings...gsr's have alot of aftermarket support it should be easy to find the parts.
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stickyicky »</TD></TR><TR><TD CLASS="quote">The last pic labeled "crank", is that a main bearing journal or a rod journal?</TD></TR></TABLE>
Couple things, look at the picture closely, it's easily distinguishable.
And, the bearing was spun on the rod, so it can't be the main journal.
Also, that crank looks pretty bad,
but any machine shop should be able to tell you if it's junk or not for cheap/free.
Well i didn look at the pic closely. If you looked at the rod bearings and saw that kind of damage, wouldnt you worry about the main bearings too?
and
Yes any machine shop could tell you if it's junk or not, but are they gonna know your engine specifics to give you a valid answer.
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stickyicky »</TD></TR><TR><TD CLASS="quote">Well i didn look at the pic closely. If you looked at the rod bearings and saw that kind of damage, wouldnt you worry about the main bearings too?</TD></TR></TABLE>
Lol, what kind of dmg? It's actually not that bad.
Now if there was dmg to the walls of that cylinder, or maybe a hole in the block,
I would suspect the main journals near that rod then.
DENCIO
Jan 3, 2010 08:52 PM
bearing, block, fixable, gsr, honda, resurfaced, resurfacing, rod, sacramentoca, sale, short, spun, tearing
