Auto Y8 intake manifold questio
Old Oct 29, 2008 | 08:45 PM
tico's Avatar
Default Auto Y8 intake manifold questio
whats up H-T. i got a Z6 with an auto Y8 intake mani. my question is scince it came out of an auto it is set up for a EGR. could i make a cap fpr the EGR port and still run fine?
Old Oct 29, 2008 | 09:07 PM
sleepingciv's Avatar
Default Re: Auto Y8 intake manifold questio (tico)
ya just cap it off youll be good to go
Old Oct 30, 2008 | 04:14 AM
4DRmafia's Avatar
Also, if your car is a manual then you gonna have to drill out holes/tap for the iacv on the back of the intake manifold and change out the throttle body for an manual one.
Old Oct 30, 2008 | 01:42 PM
imgoingforit's Avatar
Default Re: (4DRmafia)
I have a Y8 mani in my garage that I'm planning to use; I didn't know to ask if it was an auto or manual until after I purchased it. Can someone please post pictures of the difference?
Old Oct 30, 2008 | 02:49 PM
tico's Avatar
nah its already go the IACV on the back. ill post some pics up a lil later to show u guys
Old Oct 30, 2008 | 03:12 PM
4DRmafia's Avatar
there no way if the manifold came out of the automatic car, unless some previous owner swapped it out before you got the car.
Old Oct 30, 2008 | 03:26 PM
auto
manual
Old Oct 30, 2008 | 03:38 PM
tico's Avatar
Default Re: (sleepingciv)
nah look.....
Old Oct 30, 2008 | 03:48 PM
89s1's Avatar
Default Re: (tico)
look how crooked that IACV is..... it has been modified before you owned it.
Old Oct 30, 2008 | 03:54 PM
tico's Avatar
if u look again ull see that it has one bolt holding it on very loosely. i need to buy all new bolts for this swap
Old Oct 30, 2008 | 03:56 PM
89s1's Avatar
Default Re: (tico)
lol duly noted.
The only thing i can see being the case is (if those holes are factory) that is was an obd2 (jdm) d15b intake manifold.
Old Oct 30, 2008 | 04:04 PM
tico's Avatar
its a y8 mnifold though isnt it?? thats what i wa told. thats where i was confused. it has the IACV and factory machining for that sensor but it also has an EGR system also so it threw me off
Old Oct 30, 2008 | 04:11 PM
89s1's Avatar
Default Re: (tico)
in the sense that it was unbolted from a d16y8, no it isn't a y8 manifold.
but.
in the sense that it is the same casting (plenum/runners) then yes, it is.
Old Oct 30, 2008 | 04:12 PM
tico's Avatar
ahhhh ok i see what u mean. thnx
Old Oct 30, 2008 | 04:15 PM
Default Re: (89s1)
since tha back of the mani says P2J
Asian 3 stage vtec mani
d15b7 obd2 3 stage vtec
Old Oct 30, 2008 | 04:17 PM
89s1's Avatar
^^not b7, just d15b.^^
They didn't add a number after the engine casting in the asian market.
Old Oct 30, 2008 | 04:18 PM
Default Re: (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">^^not b7, just d15b.^^</TD></TR></TABLE>Opps my bad ya typo Thanks for catching that
Old Oct 30, 2008 | 04:21 PM
89s1's Avatar
understandable. being that we live in the usdm the 7 likely just comes out as part of the code.
there are alot of differences tho. the jdm 1.5L blocks are nothing like the 1.5L blocks we get in the b2 and b7.
Edit: It's nice that you took the time to cross-reference that for us tho. I had already replied that it *might* be a jdm d15b manifold and now you've basically comfirmed that.
Old Oct 30, 2008 | 04:43 PM
4DRmafia's Avatar
wow, I stand corrected then. I never seen that intake manifold before with the egr and the long strip plate on it.
Here's mine,
Nov 4, 2012 07:24 PM
codyellis
Oct 16, 2010 01:01 PM
alacard
Dec 25, 2006 11:30 PM
sloweredcivic
Jan 17, 2004 09:27 PM
SOHC_Brian
Jan 15, 2004 08:57 AM
