got a 96 b18c spec r swap in my 2000 civic coupe (Need Some Info) Thanks
Old Oct 29, 2008 | 05:43 PM
JDMfiend's Avatar
Default got a 96 b18c spec r swap in my 2000 civic coupe (Need Some Info) Thanks
alright i just swaped a 96 b18c spec r swap in my 2000 civic coupe n i have an obd2 ecu from the original single cam d16y8 that was in my car.. i knoe your supposed to use the jdm type r obd-2 ecu (p73) but i cant find one is there another ecu i can use like a gsr or just chip my p28? and 91 octaine is the only gas i should be using right?? considering the 11 to 1 compression ratio
ohh and the car back fires alot is it because the ecu and the 89 octain or the engine itself?
i apreciate your help
thanks
(OneLoveJDM)
Modified by JDMfiend at 9:01 PM 10/29/2008
dimo92
Feb 7, 2013 11:31 AM
90civicSi VTEC
Engine Management and Tuning
Oct 19, 2008 07:17 PM
loverboy
Jun 14, 2008 04:02 PM
