1993 Accord won't start correctly.
Old Oct 29, 2008 | 03:59 PM
mellophonium's Avatar
Default 1993 Accord won't start correctly.
Hello, I have a 1993 Honda Accord, and when I put the key into the III position where it is supposed to have power, nothing happens. But once I turn it a little bit more to start the car, that when the power kicks in, if I keep on turning the key the car will start, but once I let go of the key the car turns off. I checked the fuses and they all work. The battery is good too. Has anyone had any problems like? How can fix it, is it fixable without going to a mechanic? My girlfriend's dad talk to his mechanic about it, and the mechanic said he knew what the problem was and said I should bring it in, but didn't say what the problem was. Thank you.
Old Oct 29, 2008 | 04:10 PM
P_Adams's Avatar
Default Re: 1993 Accord won't start correctly. (mellophonium)
You need to replace the electrical portion of your ignition switch. Honda has issued several TSB's (and at least one recall) for this item; and the forum gets queries from time to time about this.
Here is the listing and an illustration
http://www.hondapartsdeals.com...=6796
and the part number:
35130-SM5-305
P
Old Oct 29, 2008 | 04:49 PM
Default Re: 1993 Accord won't start correctly. (P_Adams)
Cool, I'll switch it out this weekend, thank you.
Old Oct 31, 2008 | 02:26 PM
egvr4's Avatar
hey my accord is doing the same exact thing i have a 1990 but someone else told me it could be ecu. I have a red light on the ecu when there no key at all
Old Nov 5, 2008 | 02:43 PM
Default Re: 1993 Accord won't start correctly. (egvr4)
I replaced the electrical portion of your ignition switch and it works find now . Thank you for your help.
Old Nov 5, 2008 | 04:52 PM
P_Adams's Avatar
Another diagnosis successfully performed
P
Old Nov 5, 2008 | 04:56 PM
P_Adams's Avatar
What year is your accord?
How does it act?
That red light (I never paid attention to it (I confirm power with a test light)) indicates the ECM is powered. The "Check Engine Soon" lamp on your cluster display is the one to pay attention to for problems.
P
LeviKC
Jul 17, 2015 02:39 PM
Charlie32
Nov 22, 2014 04:43 PM
hondahbgurl
Jan 2, 2012 05:44 AM
jamielee
11
Jul 14, 2011 11:05 AM
derrickjon
Jun 10, 2009 08:45 AM
